rear trunk swap
Old 04-20-18, 09:26 AM
lextout
lextout's Avatar
Default rear trunk swap
hey everyone, i found a trunk with the oem spoiler and want put it on my non factory equipped spoilered trunk. is it a direct fit? being that the spoilerd trunk has a 3rd brake light or is the brake wiring different or connectors different.
Old 04-21-18, 09:34 PM
lextout
lextout's Avatar
advice would be great great guys, thanks.
Old 04-22-18, 12:28 AM
shwalker07
shwalker07's Avatar
Just from looking at GS's that I have seen in the junkyard I do not think it will be a big deal. Looks like all years use the 2 same license plate bulb connectors and center taillight section looks similar to so just make sure you have the extended brake light harness from the trunk with the spoiler since that should be the only difference. Worst case scenario you have to make/extend a small two wire harness but if you follow the wiring harness from the trunk with the spoiler on it, you should find your answer.
Side note unless you already knew: You have 3 adjustments for torsion on the trunk so when you get your trunk with a spoiler installed, you can find a good spot you prefer to make opening your trunk a bit easier. You may need to change those tension bars also from the trunk with the spoiler if the lift is not that easy due to the extra weight of the spoiler.
Old 04-22-18, 09:42 PM
lextout
lextout's Avatar
thanks for the advice, highly appreciate it.
Old 04-24-18, 12:58 AM
Tuanville
Tuanville's Avatar
There’s a blank female harness on the wiring loom of wingless trunk that plugs into the third brake light.
Old 06-06-18, 06:20 PM
lextout
lextout's Avatar
thanks guys, i got it installed .
Old 06-29-18, 03:15 PM
Kwoteman
Kwoteman's Avatar
Default Trunk swap
did you take any pic. I was thinking of doing the same thing
snakehead
SC400 / 300 Classifieds
07-18-12 01:56 PM
lexluger71
07-19-07 05:42 PM
z16
07-05-07 02:12 PM
sbgs400
10-05-06 03:16 AM
BklynJay
03-25-06 07:04 PM
Quick Reply: rear trunk swap
