Front Plastic Splash guard Pan Delete - ?
Old 04-19-18, 12:18 PM
greenRX300
greenRX300's Avatar
Default Front Plastic Splash guard Pan Delete - ?
So the front splash pan is hanging/dragging because many of the mounting bolts snapped off. Im inclined to just leave it off because it gets in the way during oil filter changes. Was wondering if leaving the splash guard off will cause any overheating issues?
Thanks, Chet
Old 04-19-18, 06:09 PM
fastnoypi
fastnoypi's Avatar
i'd attempt to repair the mounting bolts or find a way to make the splash pan work . The pan will minimize water that can splash up and rust away your radiator support. Try drilling out and using an ez out on the snapped bolts and retapping if necessary.
Old 04-20-18, 12:59 PM
salimshah
salimshah's Avatar
If the plastic (shield) has enraged holes, you can cut 2"x2" size patches from plastic containers and dill a hole for the bolt. Use these patches as a oversized washer.
Salim
Old 04-20-18, 04:05 PM
ukrkoz
ukrkoz's Avatar
Keep it. It is designed to reduce under body air drag and reduce dirt from getting onto the engine.
Little secret. Quality zip ties do great instead of factory bolts. Ask me how I know.
fig19
GX - 1st Gen (2004-2009)
12
06-02-18 01:34 PM
hsmac
29
04-14-16 09:33 PM
Banshee365
01-04-11 08:36 PM
DeanBird
Performance & Maintenance
01-04-10 05:29 PM
dallg
Maintenance
04-24-06 07:03 AM
Quick Reply: Front Plastic Splash guard Pan Delete - ?
