Spark plugs
Old 03-20-18, 08:50 PM
cbenoit65
cbenoit65's Avatar
Default Spark plugs
I need to know what is the best spark plugs for 2004 Lexus LS 430 flint mica color and 94000 mileage.
Old 03-20-18, 09:03 PM
05ls430518
05ls430518's Avatar
ngk iriduim plugs its what I used and my car runs fine.
cbenoit65 (03-21-18)
Old 03-20-18, 11:05 PM
bradland
bradland's Avatar
Denso 3297 or NGK 4589
Old 03-21-18, 04:59 AM
Jabberwock
Jabberwock's Avatar
SK20R11 Denso Iridium Long Life - about 7-8 bucks each. There may be less expensive sources but watch out for cheap fakes so check the box and plug carefully no matter where you source them. I purchased the ones below and had no issues.
https://www.amazon.com/Denso-SK20R11-Iridium-Spark-Plug/dp/B0012Q4IPY/ref=pd_cp_263_2?_encoding=UTF8&pd_rd_i=B0012Q4IPY&pd_rd_r=P89NHE35NMM2DFHDEFNN&pd_rd_w=wUXgZ&pd_rd_wg=X0ZnG&psc=1&refRID=P89NHE35NMM2DFHDEFNN&dpID=41skUf00r2L&preST=_SY300_QL70_&dpSrc=detail https://www.amazon.com/Denso-SK20R11-Iridium-Spark-Plug/dp/B0012Q4IPY/ref=pd_cp_263_2?_encoding=UTF8&pd_rd_i=B0012Q4IPY&pd_rd_r=P89NHE35NMM2DFHDEFNN&pd_rd_w=wUXgZ&pd_rd_wg=X0ZnG&psc=1&refRID=P89NHE35NMM2DFHDEFNN&dpID=41skUf00r2L&preST=_SY300_QL70_&dpSrc=detail
Old 03-21-18, 11:19 AM
caverman
caverman's Avatar
SK20R11 Denso Iridium Long Life is what I just used (122k miles).
BTW: Lexus spark plug interval is 120k so not really necessary at 94k unless you want to be proactive which is understandable as well.
Second, if your DIY then be careful when pulling the spark plug wire clips out. They are hard to push in on the release and then pulling up on them without pulling on the wires, which are pretty thin. With the age and they way you have to grab them you can easily pull or rip out a wire from the clip....ask me how I know. The first LS plug change I did I had no issues, the last one I did last week I pulled the wire on one and had to replace the clip. Which if you do accidentally there are threads on here with the part numbers and what to do.
Old 03-21-18, 11:22 AM
caverman
caverman's Avatar
I also highly recommend this. It's worth the $14 and with all the money you'll save DIY it's no brainier.
https://www.amazon.com/gp/product/B0014ZVSVK/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0014ZVSVK/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Old 03-21-18, 05:04 PM
nedear1688
nedear1688's Avatar
How can you beat this price and factory plugs https://www.ebay.com/itm/4-pcs-TOYOT...72.m2749.l2649
It came out $5+ each. FREE shipping too.
Old 03-21-18, 06:54 PM
warminwisc
warminwisc's Avatar
How easy of a job are the plugs?
Old 03-21-18, 07:03 PM
05ls430518
05ls430518's Avatar
Its super easy very good task to start out with as you learn to fix your own car. Only thing to be carefull of is dont overtighten the plugs and break them in the motor, and dont drop anything down the hole when you have the plugs removed.
Old 03-21-18, 08:03 PM
cbenoit65
cbenoit65's Avatar
Thank you!
is3504bao
09-23-22 11:01 AM
macd7919
General Classifieds
07-06-09 05:48 PM
indypwr
GS - 1st Gen (1993-1997)
12-17-02 08:19 PM
ShowGSLuVv
05-11-02 12:42 PM
Quick Reply: Spark plugs
