Car start shaking in lower rpms
Old 03-20-18, 02:37 AM
sajawalas
sajawalas's Avatar
Default Car start shaking in lower rpms
hi all. my car starts shaking in lower rpms i.e. if my car is on 80km/h and car is in 8th gear (lowest Rpm) it will start shaking unless i leave accelerator or press it even more to increase rpm then it goes normal. this only happens if my car is in lower revs i.e below 1400 revs (1.4). i tried to change the 4 tires, wheel balancing, i checked the rims and fixed them from the RIM repair shop. any other clue ? as per my mechanic all mechanical things are fine. any clue what could be the reason ?
Old 03-20-18, 09:25 AM
Tec80
Tec80's Avatar
Likely is a misfire, but that should set a check engine light. If there is no check engine light, see if you can make it shake for as long as safely possible, if it is a misfire that will log a code.
Otherwise, it could be a faulty injector. You might try 2 bottles of Techron in the tank, and/or a different brand of fuel.
sajawalas (03-20-18)
Old 03-20-18, 10:46 PM
sajawalas
sajawalas's Avatar
Dear Tech80. thanks for your suggestion. there is a check engine light and the log codes are for O2 sensors. do you think O2 sensors are the cause ? fuel injectors i've checked recently from my dealer and replaced 3 out of 16. rest are fine. they cleaned the injectors and i replaced the spark plugs as well. if you say this O2 sensors are the cause, i will replace them today.
Old 03-21-18, 09:38 AM
213374U
213374U's Avatar
Sounds like a worn engine mount to me
Old 03-21-18, 11:00 AM
yyymmm31
yyymmm31's Avatar
Which model year do you have and how many miles on the car? Your profile says that you have a LS430. If so, perhaps folks on the LS430 forum can provide you more helpful suggestions. Regardless of the model year, before you replace anything, check if you have trouble codes or not. If there are no trouble codes, it is most likely a mechanical issue such as a worn engine mount or worn suspension part. If there are trouble codes, replace or repair the necessary parts as the trouble codes indicated.
Old 03-21-18, 01:24 PM
Nospinzone
Nospinzone's Avatar
Yes, I was thinking the same thing, a loose or broken engine mount.
Old 03-23-18, 04:52 AM
sajawalas
sajawalas's Avatar
i've replaced the engine mounts. 2 engine mounts + Gear Mount + 2 rear differential mounts. problem is still the same.
Old 03-23-18, 04:54 AM
sajawalas
sajawalas's Avatar
i previously had LS430 2004 but recently i bought it before 2 months and i discovered this issue and i tried to visit all the dealers but the problem is still the same even after spending so much amounts thats why i decided to took experts suggestion by putting in club lexus
Old 03-23-18, 10:18 AM
UDel
UDel's Avatar
Have you tried changing spark plugs and do a fuel injection cleaning, normally with those issues it shakes or idle is rough when the car is not moving but it may do it at speed if it is really bad. Are you sure your tires are balanced, if they are not balanced or a weight fell off the tire the car will shake at certain speeds.
Old 03-24-18, 12:16 AM
sajawalas
sajawalas's Avatar
yes dear i've replaced the spark plugs also and cleaned the 16 fuel injectors as well. i found 3 of them were not performing well and i replaced these 3. i replaced the 4 tires and i did wheel balancing as well. also i changed the drive shaft bearing and rubbers but still the issue is same.
Old 03-24-18, 07:00 AM
Nospinzone
Nospinzone's Avatar
Well it seems you have checked/replaced just about everything. It still sounds like a tire balance problem. If you could find another owner who would let you put on his wheels and tires that would answer that question.
I don't think this would have anything to do with it based on your symptoms, but have you had a compression test done?
Old 03-25-18, 08:17 AM
213374U
213374U's Avatar
Is this an AWD or RWD model?
Old 03-25-18, 12:32 PM
BMW7_LS430
BMW7_LS430's Avatar
Post all the codes you are getting and any code history. Best to get OBDII adapter and app like Torque Lite or buy pro version.
LS430430
12-24-17 09:49 PM
Dtur15
01-05-16 04:46 PM
paulm281
09-11-13 06:37 PM
SeanD
06-19-08 04:58 PM
gsowner99
Performance
11-01-04 12:23 PM
Quick Reply: Car start shaking in lower rpms
