Driver Door Belt Strip Replacement
Old 03-18-18, 06:47 AM
hoffy5
hoffy5's Avatar
Default Driver Door Belt Strip Replacement
Can someone shed some light on the Driver Door Belt, I need to replace mine! Question, on the Belt replacement, does the replacement include both sides of the Weathersrip? Meaning, when the window goes up, my inner piece of rubber that leans toward has peeled back about 3 inches! The outer rubber is ok, Just making sure the main part includes both sides of rubber, or is that a separate piece?
Thanks!!
Bob
Old 03-18-18, 07:32 AM
VVTiBob
VVTiBob's Avatar
Unfortunately the piece you are referring to is part of the door interior door panel and not the door belt.
The door belt consists of the chrome trim and black rubber weatherstrip.
I believe the interior seal is a component that cannot be ordered separately.
If the seal is really bad, you can probably find a used panel on eBay.
The following 2 users liked this post by VVTiBob:
hoffy5 (03-18-18), JDaveSC430 (03-18-18)
Old 03-18-18, 07:46 AM
hoffy5
hoffy5's Avatar
Thanks BobVVTi to the rescue! what kind of Glue would you try to use?
Thanks!
Bob
Old 03-18-18, 08:02 AM
VVTiBob
VVTiBob's Avatar
Sorry, I have no clue on that one.
Old 03-18-18, 08:37 AM
moerbeck
moerbeck's Avatar
I have the same issue and ordered a part that is part of the interior... I should get it this week and when I replace it I will let you know.
hoffy5 (03-20-18)
Old 03-18-18, 09:19 AM
VVTiBob
VVTiBob's Avatar
Moerbeck is correct and deserves the credit.The part, called an “inner belt” weatherstrip is replaceable. The part number above fits my 02 driver’s door. So make sure you find the correct one for your needs.
Old 03-18-18, 01:01 PM
hoffy5
hoffy5's Avatar
Hi, Can you please get me the part#??
Thanks!!!
Bob
Old 03-18-18, 01:06 PM
hoffy5
hoffy5's Avatar
Ok, I spent the good part of the Day trying to glue the interior strip, what a pain in the A** I tried
3M Super Weatherstrip Adhesive Black Did not work, followed directions!
I cleaned that mess up, finally I used super glue and a Accelerator, especially made forr super glue's--- so once you put the glue on the molding, place it proper angel, hit with the accelerator, THAT Worked!
So it looks good for now! However, maybe replace it with a new one! Please send part # MOWERBECK!
Thanks!
Bob
VVTiBob
VVTiBob's Avatar
Try this one for the driver’s door on a 2003: 68172-24020
Old 03-18-18, 08:44 PM
moerbeck
moerbeck's Avatar
Smile
68172-24021
Belt Weather-strip, LEFT
$51.69
$51.69
68171-24021
These are it including the pricing!!! - got them at oemvehicleparts.com mainly because they are in Florida. I will keep you posted. Belt Weather-strip, RIGHT
$51.69
$51.69
Old 03-19-18, 11:08 AM
hoffy5
hoffy5's Avatar
Hi,
I just ordered both parts from oemvehicleparts.com from Florida! How long did it take to get the parts?
Bob
Old 10-14-21, 06:31 PM
buddhi
buddhi's Avatar
Here's the video:
I found used weather strip front and back, driver and passenger,
on ebay for cheap. Have yet to install. They look far better than
what i have, almost like new. Will first spray with ArmorAll Tire Foam,
original version, that is not ultra shiny like the AA Extreme Tire Foam.
Have heard this low gloss Tire Foam is best for all rubber, so not just
tires. Under $4 on Amazon. One guy's video showed him first cleaning
his engine, not with the car wash spray wand, which is iffy, but by hand with
cloth and cleaner, then just simply spraying the Tire Foam all over and
leaving it to really shine everything up. No need to take it off. Spray and
forget.
mandyfig (10-15-21)
Old 05-23-23, 08:42 AM
BIGSTIX
2nd gear
BIGSTIX's Avatar
Default Inner belt weather strip
I've watched a YouTube vid that shows how to replace the 'outer belt moulding'. It doesn't require removal of the inner door panel - does the install of the 'inner belt' require the removal of the door panel ???
Thanks, BIGSTIX
Old 05-23-23, 08:08 PM
PWRSLVE
PWRSLVE's Avatar
I replaced both the inner belt trims about a year ago and it does require removal of the door panels. In addition to that, you need to bend up all the metal prongs that are holding it on to the door panel and drill out a number of rivets to remove the old ones. Looking at the new parts gives you some clues also.
cbrkat28
05-20-18 05:06 PM
SMWallis
10-08-15 12:07 PM
Fern
RX - 1st Gen (1999-2003)
15
12-11-14 06:50 AM
DNC
03-07-09 05:22 AM
mmeyerkopf
11-27-06 04:18 PM
Quick Reply: Driver Door Belt Strip Replacement
