stalled while driving
Old 02-23-18, 06:20 PM
bbatman
bbatman's Avatar
Exclamation stalled while driving
Hi everyone i am a newbee to this forum and i really need help from you guys to help me solve this problem. I started my 2006 is250 a day after driving through some snow and slush, and it fired up good as all other times, before i could reach 1/4 mile from home the engine instantly lost power and stalled and would not crank over, i also noticed the transmission P R N D position shift lights on the dashboard were all off when the switch was on and my scan tool have stopped communicating with the ecm, i have checked all fuses in and out and everything thing else powers up.The starter button turns to green when i press the brakes and the other lights and guages function normal and it still wont crank over. After a new battery and 3 weeks of being down i got into the car yesterday pressed the starter button and saw the the gear position lights was lighted up, i pressed the brake and the starter button and the engine cranked over and stopped with the position shift light going blank and the starter going dead again .Please i neeeeeeeed some help to get my car running again.
Old 02-23-18, 08:56 PM
MikeFig82
MikeFig82's Avatar
You may need to look it to a full pressure sensor issue. Lately there's been many early model 2IS with this issue. Many threads on this floating around. You can check the fusible link also. Since you changed batteries you could have inadvertently shorted it out. It doesn't take much to make it blow the fuse.
Old 02-23-18, 11:20 PM
Nitrous23
Nitrous23's Avatar
Could it be the alternator starting to go? I have an '06 too and had to change mine 2 months ago.
Old 02-24-18, 12:04 AM
bbatman
bbatman's Avatar
Default Stalled while driving
Thanks for the response but would the fuel pressure sensor cause the starter not to turn and the transmission position indication lights to stay off? The alternator was removed and it was tested by a reputable technician and found to be good,I am really lost on this problem
Old 02-24-18, 03:31 AM
MikeFig82
MikeFig82's Avatar
https://www.clublexus.com/forums/is-...n-t-start.html
Old 02-24-18, 02:32 PM
bbatman
bbatman's Avatar
Thanks for the info mikeFig82 I will be on it and will let you know the outcome.
Old 02-26-18, 07:57 AM
bbatman
bbatman's Avatar
Hi mikeFig82 you were so correct about that info, I disconnected the fuel pressure sensor connector and the engine is able to crank over and the selection light is back on, the motor did not run but I guess it will as soon as I replace the sensor. I will keep you in the loop thanks again.
Old 02-26-18, 08:18 AM
MikeFig82
MikeFig82's Avatar
That's cool. Yeah it sucks trouble shooting stuff LOL. There is a PDF you can download on the procedure to install the sensor itself. You can find it on the links that have already been posted by other members. It seem to be happening more frequently on early models lately.
bbatman (03-09-18)
Old 02-26-18, 08:47 AM
Phantom_89
Phantom_89's Avatar
I wonder if there's a correlation between failing fuel pressure sensors and those who had the fuel pressure sensor gasket recall done recently. My car has been cranking longer than usual as if it's losing its fuel prime ever since I got the recall completed.
bbatman (03-09-18)
Old 02-26-18, 09:10 AM
MikeFig82
MikeFig82's Avatar
There's been instances where after the recall. The car fails and stalls again later on down the road. It's probably due to a broken wire harness. Due to a improper installation procedure.
bbatman (03-09-18)
Old 03-09-18, 02:12 PM
bbatman
bbatman's Avatar
fuel pressure sensor replaced and car is running great.
Old 03-09-18, 02:13 PM
bbatman
bbatman's Avatar
Thanks again for the information Mikefig82
Old 03-10-18, 03:51 PM
2013FSport
2013FSport's Avatar
Received 1,482 Likes on 1,236 Posts
This thread should be stickied. Just enough detail without a bunch of extras...
Old 03-10-18, 05:29 PM
2013FSport
2013FSport's Avatar
A GS owner posted this...
Originally Posted by gs350fan
Some tips if you don't have a fancy diagnostic tool. Use a hand held meter...
Originally Posted by 2013FSport
Same thing is happening on the 2IS series as we speak. The 06 - 08 crowd. That said they are replacing the sensor.
Like the video, unplugging the sensor allows the car to start.
Good find.
Note to those trying to troubleshoot (TS) this: Using engine ground and the data wire, not the 5v supply wire, one could TS this with a volt meter by back probing the data wire and reading the voltage. Engine off the pressure leaks down and with the key on one might see 0.5v. When running expect something north of 2.5v and to increase as RPM goes up.
Hint back probe is to use a very small stiff pointed probe to shove through the moisture proof connector. Again, us common engine ground for ground.
Old 03-10-18, 05:32 PM
2013FSport
2013FSport's Avatar
Good find.
Hint back probe is to use a very small stiff pointed probe to shove through the moisture proof connector. Again, use common engine ground for ground.
If the sensor is good, the voltage will rise. If the sensor is bad it will be unresponsive..
MrMark
10-13-14 10:30 AM
fwilliams
03-14-14 10:51 PM
cptfaze1
10-30-11 09:49 PM
jimmy2x
ES - 5th Gen (2007-2012)
01-12-11 12:18 PM
flyhigh123
Performance & Maintenance
12-01-06 09:08 AM
Quick Reply: stalled while driving
