Lexus RC Moonroof Wind Deflector Stuck
[Solved] Lexus RC Moonroof Wind Deflector Stuck
Anyone else have issues with their moonroof air deflector? Mine seems to be really sticky and doesn't pop up automatically. There's a rubber piece under the aluminum deflector that seems to be kind of stiff that prevents it from popping up as the glass slides back. Either that or the springs are just not strong enough. Is it meant to be flipped up manually or should it pop up automatically?
Anyone else have this issue?
I'm thinking of just trimming the rubber piece back so that less of it is rubbing against the body of the car as it goes up. It looks like the entire assembly can be bought for $137 online. Seeing as it's the subassembly, it probably even comes with the rubber seal too. If I botch up the trimming I'll probably just purchase another one here. https://www.lexuspartsnow.com/parts/...w-glass,,63209
After reading this, I opened my sunroof and checked on the wind deflector. It did not pop up by itself, but, with manipulation, it feels like there is a little bump in there somewhere that I have to give it a boost to help it pop all the way up. I sprayed some lubricant on the moving parts, but that did not seem to help. I don't open the sunroof much, so I'm going to try to live with this. Since I have not noticed this problem for the last 3 years, I think I can get along with lifting it up when I do open the roof.
But if you find the cause of this, and if there is a fix for this, please post it here.
Yes mine too. Sometimes it's pops up late.
I had this issue in my RCF, (I have a thread on it in the RCF forum) it required replacement of the sun roof track, if yo have this issue you may also notice that there is a rattle/vibration and excessive buffeting noise when the sunroof is open and the sun shade is not fully retracted, in my case we also noticed that the sun roof did not fully open, when compared to other RC vehicles my sun roof at full open had a difference of 1.75", meaning the distance from the front edge of the opening to the glass was shorter than 5 other RCs we compared.. this is what resulted in the rattle and buffeting noise.
Cerritos Lexus in Socal did it for me several months ago and I was very pleased with their handling of the whole situation. Talk to Service Advisor Sean if you go there, according to him it is a known issue on several models between 2014 and 2016, I was just in for my 30K service and he asked me about the sun roof as the repair was done about 8 months ago, he indicated since mine they have done several GS and ES models, and 1 other RC.
So I trimmed the rubber piece and now the deflector pops up but I'm getting additional wind noise because there's a little gap between the deflector rubber and the car. While looking for the replacement part, I noticed what I thought was the part 63209-24050 is actually indicated as "replaced by 63209-24051" according to LexusPartsNow. Perhaps they fixed the problem with the part. My car is out of warranty so I'm gonna just purchase this and see how it goes. Will report back later.
How can your car be out of warranty? The RC, like all Lexus cars, has a 4 year transferable warranty; the RC went on sale in the fall (Nov) of 2014 (I bought mine on the first day) which is less than 4 years ago, although I must confess math has never been my strong suit.
PS: whose idea was it to trim the rubber part on a wind deflector?
Last edited by tfischer; 03-06-18 at 12:20 PM. Reason: Removed references to "embiggen" being added to the dictionary.
The new wind deflector part came in. It's the entire aluminum piece with rubber/foam piece in the front attached. Again, I don't know if 63209-24051 is really any different from 63209-24050 but the rubber piece in the front is a little softer allowing it to pop up as intended. I don't know if it's because the old one just got stiff over time or if the new one is of a different material but the replacement is good. The spring force on the two are identical so it's really just the rubber seal in the front that feels different. I'd recommend you guys who are having the issue to have lexus replace the part and it'll be good to go.
If lexus offered just the rubber seal repalcement, taking out the rubber seal is as simple as undoing a torx screw and sliding the rubber out. It's actually simpler than replacing the windshield wiper rubber inserts.
Well, these were the things I tried.
- I greased the rubber strip which did help it pop up but it'd be very slow and make take like 5 to 10 seconds after the moonroof was fully retracted
- I then removed the rubber strip which created excessive wind buffeting.
- Then I trimmed it down but I trimmed too much which ended up not sealing completely, which created high pitched wind noises.
- A replacement with the new part, 63209-24051, finally fixed the issue.
Thanks for that info. My guess is that Lexus re-designed the part.
My car is one of the first, and it has the problem you describe; since my car is still under warranty, I'll mention this to them when I have it in for service next month, and I should get the new part with the improved pop-up mechanics, at their expense, which is the way it should be.
The headliner doesn't have to come off right?
