Current Map Data Version
Old 01-23-18, 07:39 AM
ADV
ADV's Avatar
Default Current Map Data Version
Does anyone no where I can find the current map dat version for my 2015 ES?
Thanks!!
Old 01-23-18, 12:15 PM
mcomer
mcomer's Avatar
Open "options" button in the upper left corner of the map,
select "map data" and the date will be displayed.
Your 2015 will likely show **-2014-*** as the OEM map.
Go to www.lexusdrivers.com and open "Resources".
Find Multimedia Update and enter your 2015 ES Nav and
you will find that there is a free update available, Grab a
flash drive and download it, use the USB in the console to install.
This is NOT the Navigation update for your original question but
will update various Bluetooth and voice recognition software.
Old 01-23-18, 12:35 PM
ADV
ADV's Avatar
Thanks!!! I did the update for the multimedia and found the map data. How did I know if I have the latest version? Thanks again!
Old 01-24-18, 07:45 PM
st1800
st1800's Avatar
I checked for 2014 updates and none available. Can I install the 2015 updates in my 2014 ES 350?
Old 01-24-18, 08:03 PM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
Your 2014 ES has a Generation 7 navigation system. The 2015 ES has a Generation 8 navigation system. So, I'm confident in guessing that the update for the 2015 ES would not be compatible with the 2014 ES. Also, the Generation 7 system in your 2014 ES stored map data on a hard drive. I believe that the 2015 ES Generation 8 system was when Lexus started to use an SD card for storing the map data. So, the 2015 system is completely different from what you have on your 2014.
st1800 (01-25-18)
RX469
RX - 1st Gen (1999-2003)
06-18-19 03:01 PM
Hotrod70
06-18-18 02:43 PM
rjmalm
RC F (2015-present)
01-04-16 07:49 AM
Eagleguy
04-22-13 04:31 PM
zoombie99
02-11-13 05:38 PM
Quick Reply: Current Map Data Version
