Necessary items to replace in a 20.+year old ls400
Old 01-22-18, 09:47 PM
YODAONE
YODAONE's Avatar
Default Necessary items to replace in a 20.+year old ls400
Hete are my engine component submissions;
1.) Thermostat and gasket.
2.) Coolant temperature sensor
3.) Throttle Position Sensor
4.) PCV Valve, grommet, hoses and clamps
5.).All vacuum hoses.
6.) Oil cap grommet
6.) Gas cap grommet.
7.) Valve cover gaskets
8.) Spark plug tube seals.
9.) Valve cover screw sealing washers
10.) Crankshaft and camshaft seals.
11.).All incandescent bulbs...
Anyone care to add to the list?
Old 01-22-18, 10:30 PM
Banshee365
Banshee365's Avatar
I would leave the TPS unless it's causing an issue.
As far as adding, maybe:
  • Coolant overflow tank cap
  • Battery terminals if corroded at all
Old 01-22-18, 11:55 PM
bradland
bradland's Avatar
Rear engine (aka transmission) mount
PS pump
- hose from reservoir to ps pump
Radiator
-coolant
- easy and low cost piece of mind (granted I live in Arizona)
UCA's
Fluids
-PS fluid
-Trans fluid
-Brake fluid
Old 01-23-18, 01:37 AM
Moarpower
Moarpower's Avatar
JDM owners need to be concerned about the oil hoses for their cooling fans and the cap seal on the res.
Old 01-23-18, 02:57 AM
AandSC
AandSC's Avatar
Strut rod bushings should also be on the list.
Old 01-23-18, 06:29 AM
Scraape
Scraape's Avatar
Serpentine Idler and Tensioner Bearings.
Oil Control Valve/VVT Solenoid
Fuel Filter
Power Steering Air Control Valve
Diff Drain and Fill
Upper Strut Mounts
Engine Mounts
Power Steering Rack Bushings
Sway Bar Bushings
saleenssc (03-27-18)
Old 01-23-18, 02:20 PM
valex
valex's Avatar
6.) Oil cap grommet
Yoda,
Do you have the part numbers for the vacuum hoses you mentioned? Mine is a '99LS, would like to have all parts ready before I change the starter.
Old 01-23-18, 03:31 PM
tannnr
tannnr's Avatar
Originally Posted by valex
Yoda,
Another one here asking for the vacuum hose part numbers please. I've got a 1998 LS so it should be all the same
Old 01-23-18, 05:24 PM
YODAONE
YODAONE's Avatar
Refer to exploded parts diagrams and contact Lexus....they will.assist you. Have VIN # ready
A link to site with P.N.'s
https://www.lexussouthatlantaparts.com/showAssembly.aspx?ukey_assembly=1176067&ukey_make=1082&ukey_model=15669&modelYear=1999&ukey_category=21750
Old 01-23-18, 11:53 PM
Losiracer2
Losiracer2's Avatar
I still have the original VC gasket and tube seals and only now they're starting to become an issue with some slight oil drips occasionally at 287k.
Old 01-25-18, 12:14 PM
nthach
nthach's Avatar
It really depends on the shape of the car and how much $ are you willing to spend. I replace leaky gaskets if they are easy to get to or if other PM needs to be done. If you're changing the spark plugs, you might as well go in and replace the valve cover gaskets, spark plug tube seals and grommets. If you're doing a timing belt change, you're replacing the water pump gasket and the thermostat housing O-rings while you're in there. Don't touch the TPS unless you need to - like the CEL turning on and there's a code related to that.
As for the soft parts on the suspension, do those when you're replacing the shocks or if you hear clunking sounds over bumps. Doesn't hurt to install new OEM engine/trans mounts. I wouldn't touch the bulbs unless you need to replace a burned out one. The OEM Toshiba or Koito bulbs in these cars do live a long life but all bulbs do burn out or break.
Old 01-25-18, 12:23 PM
YODAONE
YODAONE's Avatar
Burnt out bulbs = probable cause for stop by law enforcement...
Old 01-25-18, 12:45 PM
nthach
nthach's Avatar
That's true - but I don't usually replace bulbs out of prophylaxis unless they are HID xenon bulbs or headlights. Then it makes sense to replace in pairs.
Old 01-25-18, 01:36 PM
YODAONE
YODAONE's Avatar
AM literally replacing my bulbs with propylaxis:
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/877094-center-stop-lamp-improvement.html
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/877653-tail-lamp-lense-upgrade.html
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/874861-side-marker-lenses-improving-color-uniformity.html
Old 01-29-18, 11:52 AM
dveneman
dveneman's Avatar
Vepagoo Lexus LS400 1998-2000 Gas Charged Hood Lift Support Shock Strut (Set of 2) $18.99
Consider hood shocks as well . My hood slammed shut while lowering my car with a floor jack. Yikes!
These work really well. We will see how long they (currently unavailable on Amazon now) hold up. The old set lasted 4 years.
Quick Reply: Necessary items to replace in a 20.+year old ls400
