2gs on 245/45r/18's?
Yesterday, I bought this 2000 GS400 platinum edition with 186005mi. Its a platinum edition which, from what I gather, doesn't mean much. I bought it from the second owner who had it maintained by the local Toyota dealer and had records from '00-'12. Not bad considering I've never bought a used car with an official service history.
Took a few shots after papers were signed.
I know what you're thinking...."DAMN THATS A BIG DENT"
Why yes, yes it is a big dent
Its got a dent and some rust(and the trunk lid has UV damage to the clearcoat). BUT......it was only $2k and I had already talked him down $250. The cosmetic portion of this vehicle will receive attention later in its life.
What I need help on is this: I'm looking at picking up some 18" Sport Edition ST3's wrapped with Blizzak 245/45/18. Now there's not a ton of life left on the tires and I'm going to need a summer set of rubber anyways. I looked at the 2gs wheel fitment guide(see link) and it doesn't exactly mention 245/45/18. I get the feeling that means it may not fit. Can anyone weigh in on this? Also, it looks like they might be ET 44 if that helps as well.
*edit* They're 18x8's
I have this as your oem: 235/50ZR17 95Z8Jx17 ET41
Is this correct?
Knowing what you have right now helps with determining what you want.
What offset are the ST3s that you want?
Is this correct?
Assuming your current offset is 42:
Section width235 mmSidewall height106 mmOverallwheeldiameter 643 mmFenderWheelwellBrakesSuspensionRim width203 mmRimdiameter 432 mmOffset 42 mmBackspace 144 mmFenderclearanceWheelwells clearanceSuspensionclearanceZero scrub radiusSection width245 mmSidewall height110 mmOverallwheeldiameter 678 mmFenderWheelwellBrakesSuspensionRim width203 mmRimdiameter 457 mmOffset 42 mmBackspace 144 mmFenderclearanceWheelwells clearanceSuspensionclearanceNegativescrub radius Plus Sizing 235 mm245 mm255 mm265 mm275 mm17 " plus zero235/40R17 x 8 ET46-3.6 %
235/45R17 x 8 ET42OE
235/50R17 x 6.5 ET38+3.7 %245/40R17 x 8.5 ET45-2.4 %
245/45R17 x 8.5 ET40+1.4 %255/40R17 x 9 ET43-1.1 %
255/45R17 x 9 ET39+2.8 %265/35R17 x 9 ET47-4.0 %
265/40R17 x 9 ET42+0.1 %
265/45R17 x 9 ET37+4.2 %275/35R17 x 9.5 ET45-2.9 %
275/40R17 x 9.5 ET41+1.4 %18 " plus one235/35R18 x 8 ET46-3.3 %
235/40R18 x 8 ET42+0.3 %
235/45R18 x 8 ET38+4.0 %245/35R18 x 8.5 ET45-2.2 %
245/40R18 x 8.5 ET40+1.6 %255/35R18 x 9 ET43-1.1 %
255/40R18 x 9 ET39+2.8 %265/30R18 x 9 ET47-4.2 %
265/35R18 x 9 ET42+0.0 %
265/40R18 x 9 ET37+4.1 %275/30R18 x 9.5 ET46-3.2 %
275/35R18 x 9.5 ET41+1.0 %19 " plus two235/30R19 x 8 ET45-3.0 %
235/35R19 x 8 ET41+0.6 %
235/40R19 x 8 ET37+4.3 %245/30R19 x 8.5 ET44-2.1 %
245/35R19 x 8.5 ET40+1.7 %255/30R19 x 9 ET43-1.1 %
255/35R19 x 9 ET39+2.8 %265/25R19 x 9 ET47-4.3 %
265/30R19 x 9 ET42-0.2 %
265/35R19 x 9 ET38+3.9 %275/25R19 x 9.5 ET46-3.6 %
275/30R19 x 9.5 ET41+0.7 %
275/35R19 x 9.5 ET36+5.0 %Original equipment (OE) wheel/tire size
Recommended alternatives
Optional alternatives
17x8
17x8.5
17x9
18x8
18x8.5
18x9
18x9.5Circumference 2021 mm2129 mm↑ 5%Revs per mile796756↓ 5%SpeedometerAssuming that this is OE tire and speedometer readings are correctWhen speedometer reads 60 km/h actual speed will be 63.2 km/hTypical Weight10.5 kg11.6 kg↑ 10%Rim + Tire Weight21.2 kg23.6 kg↑ 11%ClearanceWheel 1Wheel 2Suspension Assuming that this is OE wheel/tire and there is no any problems with clearance on both sidesTire is 5 mm closer to suspension components. Acceptable for most carsFenders Assuming that this is OE wheel/tire and there is no any problems with clearance on both sidesTire will stick out 5 mm farther. Acceptable for most carsWheelwells Assuming that this is OE wheel/tire and there is no any problems with clearance on both sidesWill fill out the wheelwell by extra 17 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rimsBrakes Assuming that this is OE wheel/tire and there is no any problems with clearance on both sides100% clear (leaves even more room than OE)Scrub Radius Zero scrub radius (zero value is assumed by default)Negative scrub radius (about -6 mm). Scrub radius will be changed by -6 mm, this may affect the car's handling. Please check manufacturer recommendations. Please be aware that calculated value is approximate.
Minus Sizing
RimsRim 1 (17x8 ET 42)Rim 2 (18x8 ET 42)Rim Diameter 432 mm457 mm↑ 6%Rim Width 203 mm203 mm=Backspace 144 mm144 mm=Offset 42 mm42 mm=Typical Weight10.7 kg12 kg↑ 12%TiresTire 1 (235/45 R17)Tire 2 (245/45 R18)Section Width 235 mm245 mm↑ 4%Sidewall 106 mm110 mm↑ 4%Overall Diameter 643 mm678 mm↑ 5%Rim Sizes17x7.517x8
17x8.5
17x9
18x8
18x8.5
18x9
3COOL5ME (01-22-18)
MedicalDoc, I could not ask for a more detailed response. Thank you.
So it looks like I'll be a bit tall but the wheel will be the same distance from the suspension components. With 235/40/18's on there these wheels should be snug but will clear the wheel well(from the data above). Can you tell me what input parameters you used on this website?
I looked it up in two:
http://www.willtheyfit.com/
https://www.wheel-size.com/
The parameter were the ones you gave me. Look at the bottom of post # 7.
Awesome well it looks like it'll be damn close, but I'm picking up the car the same day as I'll be looking at the wheels so I'll pop them on there and see if its too close. Thanks again for the detailed response!
245/45-18 is too big. It's 13mm (1/2") taller than the tallest OE size (215/60-16).
Recommended sizes: 245/40-18 or 235/40-18. 235/40-18 is the same diameter as the OE 235/45-17. 245 is 8mm taller, negligible. They do have a bulgier appearance compared to the 235, as a result of that extra sidewall and width, especially on an 8" wheel.
265/40-18 not recommended for 8" wheel, and is taller than recommended.
18x8 +42 leaves loads of clearances on both the inside and outside, you will have no issues whatsoever if you choose appropriately sized tires.
For future reference the OE 17x8 has an offset of +50.
n1ck (02-22-18)
