Need help: Fog lights
Old 01-20-18, 01:37 PM
MStep85
MStep85's Avatar
Exclamation Need help: Fog lights
Hey all need help please. I want to put better fog lights, better than stock, in my ES 350 2013. I have no clue what fits, and the shop thats fixing something for me dont have an electric guy but they said they will install it if i get them the whats needed.
Ive been reading the forums and im lost, Led, HID..LMNOP....
Can someone please give me a link on amazon with good strong fog lights which these guys can install and are around 50ish?
Any help would be appricated
Old 01-20-18, 02:55 PM
bc6152
bc6152's Avatar
Received 1,231 Likes on 864 Posts
If you do a search on this forum you'll find numerous posts shortly after the 2013 models came out where owners upgraded their fog lights, taillights, and headlights.
Some switched to LED's, some to HID, etc. Just search "fog lights".
Old 01-20-18, 07:06 PM
GES
GES's Avatar
Your best bet is to go with the LED for the fog lights. HID for fog lights will require a relay to the battery.
The color temperature has to be between 4300k and 5000k if you want the color to match the daytime running lights. not sure what type low beam you have.
check the lumens on the lights before purchasing. The higher the lumen the higher the light out put. There are numerous options, read the reviews and pick one.
Old 01-21-18, 01:44 PM
Nelexus88
Nelexus88's Avatar
Easiest swap would be Lexus LED fog lights from 2014 or newer ES as they were standard after 2013. Not sure on the dealer price for new ones but used ones should be easy to find for much less.
Old 01-22-18, 04:18 AM
Halfmoon
Halfmoon's Avatar
Just replaced the bulb only on my 2013 with these from amazon. They look great!
:Cougar Motor H11 H8 LED Fog Light/DRL Bulbs - CREE 60W 5000K Bright White (Pack of two bulbs) $19.99​​​​​​
Old 01-23-18, 12:02 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
You could have a look at our H16 Xtreme LED CMB bulbs for your Fog Lights. They are designed to be more a Cosmetic change, rather than a Functional brightness upgrade, but they will definitely be brighter than a stock H16 halogen bulb like you currently have. These are available in 5000K (White) and 6000K (White/Blue) for colour-matching purposes, and a simple plug-and-play bulb replacement.
Generally speaking, if you want something that is going to be much brighter than the stock equivalent, you will probably need to look at LEDs that have additional components that go with them, and that will, necessarily, bump up the price a bit, but there are a wide variety of options out there.
~Robert
SethP
RX - 1st Gen (1999-2003)
07-22-20 04:40 PM
Chandler7
07-21-14 05:32 AM
Duck05
03-11-13 08:06 PM
Quick Reply: Need help: Fog lights
