Help! Caliper clearance
Old 01-19-18, 09:04 PM
l33ks
l33ks's Avatar
Default Help! Caliper clearance
Just bought these some new wheels and the fronts don't clear the calipers on my '16 is350 Fsport tried on 10mm spacer and still no and I feel any bigger of a space will be too aggressive. Wheel specs in the front are 19x8.5 + 36 but I made the mistake of selecting the Face2 variation of the wheels for the fwhich are more concave designed so the inner part of the wheel spokes where they start to dip in makes contact with the caliper. I had this idea that if I got a BBK so that the calipers would be further out due to larger disk diameter..they would clear cause it'd be under the part of the wheel that isn't as caved in. Any other suggestions would be immensely appreciated!
The wheels are the Gramlights 57ANA
Old 01-19-18, 10:40 PM
Tilley
Tilley's Avatar
In my experience with previous vehicles, your only option is to run a spacer. I've seen guys shave calipers down... but I personally would never recommend that. I've also seen guys machine the wheel down... also something I personally would not recommend. But, I have seen both done. Nice wheels though!
Old 01-20-18, 12:18 PM
Miintt
Miintt's Avatar
I could be wrong but I think this might be a problem because of the spoke design since you said even a 10mm spacer didn't work. I also got 19x8.5 wheels +35 in the front which look a little more concave in the front than yours but a small 3mm spacer was able to fix my problem of caliper clearance
Old 01-20-18, 01:35 PM
l33ks
l33ks's Avatar
Yea it is indeed the spoke design, the back curves in greatly towards the center this oic shows where contact was made.
eicca
12-18-18 09:26 AM
Grouchy
05-25-13 07:46 PM
Low Life
11-25-12 02:07 PM
Virulent
04-15-12 02:18 PM
cupete
Suspension and Brakes
03-19-02 01:20 PM
Quick Reply: Help! Caliper clearance
