DRLs
Old 01-18-18, 01:51 PM
daddiojigg
daddiojigg's Avatar
Default DRLs
Before you tell me to do a search; let me tell you i have.Obviously not successful.
Do all sc430's have DaytimeRunningLights? If not, what year-if any- did they start in?
Thankyou.
Old 01-18-18, 02:03 PM
Coleroad
Coleroad's Avatar
Yes they all have drl's .
Old 01-18-18, 02:05 PM
daddiojigg
daddiojigg's Avatar
Thankyou.All i could find were 2009&2010 brochures that mentioned it. Could not locate other years.
Old 01-18-18, 02:11 PM
Coleroad
Coleroad's Avatar
They can also be turned on or off by the dealer, or with techstream.
Old 01-19-18, 01:57 PM
GmanSC
GmanSC's Avatar
You can also add one, after you turned off the factory DRLs
Pretty bright
Old 01-20-18, 06:11 AM
mandyfig
mandyfig's Avatar
SC
IS
I tapped into an ignition ON source so it is on when the car is on.
Old 01-22-18, 12:39 PM
GTPMAGNA
GTPMAGNA's Avatar
GmanSC - like the look, can you tell me what after market lights to bought? I have tried a few different ones and each time they go bad because water has gotten into the housing of the LED lights.
Thanks
Old 01-22-18, 12:40 PM
GTPMAGNA
GTPMAGNA's Avatar
Mandyfig, same question. where did you get your lights?
Old 01-22-18, 03:20 PM
GmanSC
GmanSC's Avatar
They are called COB- They have no housing so no water could get into. They are so bright, much brighter than the foglights, so you can use them as one.
Mandy and I have the same lights. You can search this forum under “ my new drls installed”. All the infos are in there. Mandy can provide the link.
Old 01-22-18, 08:49 PM
StillLine
StillLine's Avatar
Default Still working great!
https://www.clublexus.com/forums/sc4...installed.html
I installed these COB DRLs 3.5 years ago and they still work great and look the same to this day.
StillLine
nzxyxy (01-04-24)
Old 01-23-18, 04:16 AM
daddiojigg
daddiojigg's Avatar
Default Forgive my ignorance
but why would you install these lights when all you have to do is turn them on with techstream(from what i understand) ? As well one of you say they are too bright for night travel, so what is the point other than to trick it out?
Thanks.
Old 01-23-18, 05:36 AM
GmanSC
GmanSC's Avatar
Thanks.
Simple. The OEM DRLs are yellow and ugly. Intalling the COB give the SC modern looks. I love the brightness, for safety reason, either driving at night or in the daylight.
Old 01-23-18, 01:22 PM
mandyfig
mandyfig's Avatar
StillLine
Love these, except can not install mine like this way since I have an older SC. No perfect location like yours, mine ended up in the grill.
kurama
Build Threads
07-07-20 07:31 PM
Searosis
03-16-19 09:46 PM
Boomin
10-15-18 11:07 AM
propcop
08-22-18 08:32 PM
MatthewH
ES - 5th Gen (2007-2012)
04-04-18 01:15 PM
Quick Reply: DRLs
