91 LS 400 strange problem starting
Old 01-18-18, 05:21 AM
pacerdonfl
pacerdonfl's Avatar
Default 91 LS 400 strange problem starting
My 91 LS 400 has 150k miles on it - runs beautifully but has developed a starting quirk/issue???
Overnight, it went from a nice normal fairly quick crank/start to a long crank start.
After a day or two of this, I discovered that if I turn on the key for a quick (about 1 second) crank then off, then start it again, it cranks right up.
This is pretty much hot or cold...
Any ideas would be much appreciated.
As an aside, I have a 2001 Dodge Ram 1500 than developed the exact same symptoms, overnight.
/Don
Old 01-18-18, 03:24 PM
Amskeptic
Amskeptic's Avatar
/Don
The cure requires a correct diagnosis. The diagnosis would involve testing your fuel line pressure at shut-off against the required residual pressure. If you lose pressure quickly at shut-off, the fuel will vaporize in the lines during heat-soak. Then your morning start is trying to re-prime the fuel rail.
IF the above symptom was noted only when cold, I would question the cold start valve circuit. Otherwise, warm and cold:
a) leaky injector
b) leaky check valve at pump or regulator
Colin
Old 01-22-18, 03:50 AM
pacerdonfl
pacerdonfl's Avatar
Thank you. Colin - Hot/cold - makes not difference. One quick crank, then off, then next crank, it cranks right up.
I'm guessing the fuel pump check valve is part of the fuel pump itself?
Is there a check valve at the pressure regulator, or is that itself possibly the culprit?
Thanks so much for taking the time to respond.
I will check these out.
/Don
cdome
12-03-14 01:35 AM
DRN10DDL37
01-24-14 08:17 PM
winner155
24
02-15-12 05:13 PM
petendeb
10-12-10 02:07 PM
Quick Reply: 91 LS 400 strange problem starting
