How to remove overhead console?
Hello, everyone. I want to hardwire a dash cam on my daughter's '15 NX200t. I am planning on tapping into the sunroof switch for the 12v. Does anyone know how to remove the overhead console without breaking it? On my GS it was easy, two screws inside the sunglasses holder and it pops out.
Thanks.
Thanks.
I can concur with that. try to get your fingertips under the plastic trim and just yank downward. Hopefully, get about 6 fingertips, any less and it gets rather painful.
Last Modified: 11-08-20166.6 ADoc ID: RM100000000GWTKModel Year Start: 2015Model: NX200TProd Date Range: [10/2014 - ]Title: INTERIOR PANELS / TRIM: ROOF HEADLINING: DISASSEMBLY; 2015 - 2017 MY NX200T [10/2014 - ]
[img]Resources/B390692.png[/img]2. REMOVE VANITY LIGHT ASSEMBLY
HINT:
Use the same procedure for both vanity light assemblies..(a) Detach the 2 claws A and separate the bulb holder from the vanity light assembly as shown in the illustration.
[img]Resources/B307750C02.png[/img]*1
Bulb Holder
*2
Claw A
*3
Claw B
(b) Detach the claw B and remove the vanity light assembly.
3. REMOVE NO. 1 ROOF SILENCER PAD (for Normal Roof)(a) Remove the No. 1 roof silencer pad.
[img]Resources/B387493.png[/img]4. REMOVE NO. 2 ROOF SILENCER PAD (for Normal Roof)(a) Remove the No. 2 roof silencer pad.
[img]Resources/B387486.png[/img]5. REMOVE NO. 3 ROOF SILENCER PAD (for Normal Roof)(a) Remove the 2 No. 3 roof silencer pads.
[img]Resources/B387494.png[/img]6. REMOVE REAR ROOF SILENCER PAD (for Normal Roof)(a) Remove the rear roof silencer pad.
[img]Resources/B377884.png[/img]7. REMOVE REAR ROOF SILENCER PAD (for Sliding Roof)(a) Remove the rear roof silencer pad.
[img]Resources/B377889.png[/img]8. REMOVE NO. 4 ROOF SILENCER PAD (for Normal Roof)(a) Remove the No. 4 roof silencer pad.
[img]Resources/B387495.png[/img]9. REMOVE ROOF HEADLINING PAD (for Normal Roof)(a) Remove the 2 roof headlining pads.
[img]Resources/B377886.png[/img]10. REMOVE ROOF HEADLINING PAD (for Sliding Roof)(a) Remove the 2 roof headlining pads.
[img]Resources/B377891.png[/img]11. REMOVE FRONT ROOF HEADLINING SIDE PAD (for Normal Roof)(a) Remove the 2 front roof headlining side pads.
[img]Resources/B377887.png[/img]12. REMOVE ROOF HEADLINING END PAD (for Normal Roof)(a) Remove the 2 roof headlining end pads.
[img]Resources/B377885.png[/img]13. REMOVE ROOF HEADLINING END PAD (for Sliding Roof)(a) Remove the 2 roof headlining end pads.
[img]Resources/B377890.png[/img]14. REMOVE NO. 2 ROOF HEADLINING SUPPORT (for Normal Roof)(a) Remove the No. 2 roof headlining support.
[img]Resources/B387482.png[/img]15. REMOVE ROOF HEADLINING SUPPORT (for Normal Roof)(a) Remove the roof headlining support.
[img]Resources/B387484.png[/img]16. REMOVE NO. 1 ROOF WIRE (for Normal Roof)(a) Turn the visor connectors approximately 90° counterclockwise and remove them from the roof headlining.
[img]Resources/B364695.png[/img](b) Remove each piece of tape and the No. 1 roof wire from the roof headlining.
[img]Resources/B387496C02.png[/img]*A
w/o Lane Departure Alert System
*B
w/ Lane Departure Alert System
*C
w/ Humidity Sensor
*1
No. 1 Roof Wire
[img]Resources/V100155.png[/img]Tape
(c) Remove the butyl tape remaining on the roof headlining.
17. REMOVE NO. 1 ROOF WIRE (for Sliding Roof)(a) Turn the visor connectors approximately 90° counterclockwise and remove them from the roof headlining.
[img]Resources/B387497C02.png[/img]*A
*B
*C
w/ Humidity Sensor
*1
No. 1 Roof Wire
18. REMOVE NO. 4 ROOF HEADLINING SUPPORT (for Normal Roof)(a) Remove the No. 4 roof headlining support.
[img]Resources/B387480.png[/img]19. REMOVE NO. 3 ROOF HEADLINING SUPPORT (for Normal Roof)(a) Remove the No. 3 roof headlining support.
[img]Resources/B387481.png[/img]20. REMOVE NO. 4 ROOF HEADLINING SUPPORT (for Sliding Roof)(a) Remove the No. 4 roof headlining support.
[img]Resources/B387487.png[/img]21. REMOVE NO. 3 ROOF HEADLINING SUPPORT (for Sliding Roof)(a) Remove the No. 3 roof headlining support.
[img]Resources/B387488.png[/img]22. REMOVE NO. 2 ANTENNA CORD SUB-ASSEMBLY
Click here [img]Resources/info.gif[/img][img]Resources/footer.left.jpg[/img][img]Resources/footer.right.jpg[/img]
DISASSEMBLY
PROCEDURE
1. REMOVE CHILD RESTRAINT SEAT TETHER ANCHOR COVER(a) Detach the 2 claws, 2 guides and remove the child restraint seat tether anchor cover.[img]Resources/B390692.png[/img]2. REMOVE VANITY LIGHT ASSEMBLY
HINT:
Bulb Holder
*2
Claw A
*3
Claw B
*B
*C
w/ Humidity Sensor
*1
No. 1 Roof Wire
*B
*C
w/ Humidity Sensor
*1
No. 1 Roof Wire
