Visual inspection: Are these bushing in bad shape?
Old 01-17-18, 05:37 PM
markdav801
markdav801's Avatar
Default Visual inspection: Are these bushing in bad shape?
Please check photos. Slight cracks..
If they are usable, how many more miles should I go with them on?
or should I buy a new set ASAP.
Thank you!
Attached Thumbnails Visual inspection:  Are these bushing in bad shape?-e2801cc6-6c21-4491-b81b-825b7a735809.jpeg   Visual inspection:  Are these bushing in bad shape?-e28f2840-156e-4e46-b2a7-1a7b01abe8fc.jpeg   Visual inspection:  Are these bushing in bad shape?-86c3ba7b-2738-4bcd-a0cf-3a7c2e02e8a8.jpeg   Visual inspection:  Are these bushing in bad shape?-884be719-eb23-4b27-a6ab-61418a54a741.jpeg
Old 01-17-18, 05:51 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Yes, IMO, they should be replaced. They are showing cracks.
I have a set with few miles, 36K, from an ISF, a little stiffer than yours.
Lou
markdav801 (01-18-18)
Old 01-17-18, 06:11 PM
markdav801
markdav801's Avatar
Lou
Thanks for the input! If more people suggest, I may place an order for them tonight!Are yours for sale? Or just stating you put the ISF ones on..?
Old 01-17-18, 06:46 PM
flowrider
flowrider's Avatar
^^^^I have an ISF and replaced mine with RRRacing bushings. So they are off the car and available.
Lou
Old 01-17-18, 09:31 PM
knyg
knyg's Avatar
I have a set of bushings from a 2010 is350. Also from being replaced by RRracing bushings
Old 01-18-18, 04:54 AM
sinister2c
sinister2c's Avatar
Looks like normal wear and use to me. Unless they are cracked all the way thru and spinning loose inside, these look normal for age of vehicle. Cars in harsh winter climates probably drive around with worse.
Old 01-18-18, 05:37 AM
jr4div2
jr4div2's Avatar
I agree. Those are just surface cracks. Leave them on. Wait until they get much bigger or you start to hear anything if you want to get as much out of them as you can.
Old 01-18-18, 08:23 AM
markdav801
markdav801's Avatar
Thanks all for your input!
Old 01-18-18, 08:27 AM
MedicalDoc
MedicalDoc's Avatar
What model/year car do u have? How many miles?
Old 01-18-18, 10:46 AM
XSV
XSV's Avatar
mine were cracked like that and had play in them on the lift, got them replaced.
Old 01-18-18, 05:12 PM
markdav801
markdav801's Avatar
2008 is250. 91k mi
Old 01-19-18, 03:55 AM
Aspect
Aspect's Avatar
Personally I'm in the process of replacing most of my bushings and ball joints. 10 year old rubber in Canadian weather isn't doing the longevity of them any favors. If it's not giving you any weird symptoms like creaks or pops and there's no play, then I would leave it
markdav801 (01-19-18)
Old 01-19-18, 07:40 AM
MedicalDoc
MedicalDoc's Avatar
On a 10-year-old car with 91k miles they look like they should. Unless the crack goes all the way thru the bushing--considering that you have not described having any problems--, I would leave them alone.
Old 01-19-18, 10:39 AM
bazzle01
bazzle01's Avatar
Ive just changed mine with stiffer oem ones (prob same as ones from member above).
See my post here:in Australian forum.
http://au.lexusownersclub.com/forums...-arm-brackets/
Good video link to showing flex in soft ones.
Easy to change out and ride feel is much better.
Old 01-22-18, 09:38 PM
leoshueh
leoshueh's Avatar
My 11-year old 2IS has only 75K kilometers.
As cracks were developing on my bushing, I have them just replaced with stiffer ones too.
The mechanic told me that the bushing is fluid-filled, similar to the structure of fluid-filled engine mount.
The following 2 users liked this post by leoshueh:
bazzle01 (01-24-18), markdav801 (01-29-18)
Quick Reply: Visual inspection: Are these bushing in bad shape?
