How To Turn Off Auto-Braking And Warning When Parking?
Old 01-17-18, 03:54 PM
kvtram
kvtram's Avatar
Question How To Turn Off Auto-Braking And Warning When Parking?
When parking in my garage, I have to park it really close to the stairs to give myself enough clearance to close the garage door. I have a few safety cones and a parking laser light to guide me into the same spot every time. My issue is that the RX will auto brake suddenly and start sounding alarms when I am inching forward to the sweet spot. This is working as designed, but can this be turn off by the ICS/park assist/RCTA or combination of?
Old 01-17-18, 04:15 PM
qvtruong
qvtruong's Avatar
You can go to the settings and turn park assist off
Old 01-17-18, 04:31 PM
kvtram
kvtram's Avatar
Park assist is just for the buzzer sound and navi screen display? It doesn't actually control the auto-braking does it?
Old 01-17-18, 04:53 PM
qvtruong
qvtruong's Avatar
I believe it controls those sonar parking sensor, so it will turn off the buzzer and auto-break. It will turn off the green cone indicator on the instrument panel. I dont think the navi display is park of park assist. You can try to turn park assist off and see if its still show up when backing up.
Old 01-17-18, 06:48 PM
qvtruong
qvtruong's Avatar
I just tried. Turning parking assist off still shows the navi screen and the buzzing sound.I guess turning off the ICS will disable the auto break.
Old 01-17-18, 09:53 PM
computerwi
computerwi's Avatar
Do you have the brake hold feature on? If you're crawling so slow that you come to a stop, it will hold instead of inching forward. The pre-collision system (PCS) auto-braking does not engage below a certain speed.
You can adjust the parking sensor display and sound options under the vehicle settings in the navigation menu.
Old 01-18-18, 06:52 AM
chunktwo
chunktwo's Avatar
i have had the same issue as you.. i think short of disable the safety/parking sensor systems each time you park in your garage... you are SOL.
What i have learned to do is creep up VERY slowly.. i use a wood chuck on the ground to stop the car from going too far forward... rather than drive up to the wood chuck with any amount of speed.. i slowly creep up until the tire is stopped by the wood chuck.. (hope this made sense)
the auto-brake used to engage once every other day - but for the last month or two.. i have adjusted the way i pull in so the auto-brake isnt engaged and i stopped the same place every time because of the wood chuck.
Old 01-18-18, 08:48 AM
soholexus
soholexus's Avatar
Why don't you hang a small rubber ball or something like that from the ceiling instead of using safety cones?
Old 01-18-18, 10:02 AM
ravenuer
ravenuer's Avatar
I do the same as you, with a short piece of 2x4. Works great.
chunktwo (01-19-18)
Old 01-18-18, 10:56 AM
fredw1
fredw1's Avatar
Ditto. A 2 x 4 is perfect.
chunktwo (01-19-18)
Old 01-18-18, 12:19 PM
Jiggz858
Jiggz858's Avatar
I use a 16" 4X4 with a tape marking to make sure it is properly positioned. And yes, I believe if you turn off the ICS the parking assists and braking will go away. Just make sure you turn it back on.
Old 01-18-18, 01:53 PM
kvtram
kvtram's Avatar
Thumbs up
Will try turning the ICS off as it concurs with the manual but just double checking with folks experience here.
Old 09-20-19, 07:18 AM
Brlee
Brlee's Avatar
Default How to turn off ics
The cargo basket I installed blocks the sensors so I can’t back up now. Plz help
Old 09-20-19, 09:45 AM
jim256
jim256's Avatar
Look for ICS in the manual, on off is on the display between the speedo and tach.
pam1980
RX - 3rd Gen (2010-2015)
07-01-19 01:10 PM
choff
09-08-18 09:05 AM
jayy178
NX - 1st Gen (2015-2021)
11-22-15 01:50 PM
DrKeith
08-25-12 07:19 AM
varithms
RX - 1st Gen (1999-2003)
15
11-21-10 05:59 AM
Quick Reply: How To Turn Off Auto-Braking And Warning When Parking?
