2007 Lexus IS250 Won’t start
so I have a Lexus IS 250 2007 just had got into an accident on front passenger bumper side. So it ran completely normal for 3days and took it to a body shop and then a week later it started up then couple second turn off on its own. Then 2 days later the battery died so I went to charger it at auto zone . After that putting the battery back then I go and push the start button just goes to turn the power on but when I press it again it doesn’t wanna start up like normal cars do... it doesn’t do anything . No noise or anything . I plug in a scanner and the scanner says Error doesn’t have communication to the computer ... so now I have no idea what’s wrong with the car.. anyone had or headed someone have this problem .
You;'re posted in the wrong section, but whatever.
Have your charging system checked. Based on the age of your car and the fact your battery died, I suspect your alternator has gone bad and possible taken some fuses with it which is very typical when this particular part of the car fails.
ill Double check and see if that mite be the cause
ahunny22
03-17-15 01:11 PM
