Wheel fitment questions
I just purchased a set of wheels. Specs are 19x10 +15 and 19x11 +6. I added a 15mm spacer to clear the brakes up front. I was just wondering if Any of you guys are running similar specs. I know it’s aggressive fitment.. I will be rolling the front fenders and shaving the rear fenders. I have the youzealand kit for the rear and Nagisa RCA up front. Still need to purchase the arms for the rear from Figs engineering.
If you have any pictures or advice let me know..
for advice buy front rca bushings they were out and rely mess up the inside of your tire i burned through a set of tires is 14,000 cause of this.
They're 20x8.5 and 20x10 Advanti N707. Unsure of offset off hand but the rears need a smidge more camber as they scrub the rear quarters over bumps at speed. Otherwise they fit really well. I did have to shave a slice of schnitzel off the front of the brake calipers as they fouled the wheels just a bit as they're fairly concave. There's about a thick black Mediterranean one of clearance now
