Houston 2012 ISF for Sale. Anyone got any info!
I'm interested in this ISF in TX. I checking if the owner is on the forums or if anyone has any information about this one first hand. One owner, but it has had brake, rotors, and alignments work done quite often. This leads me to believe it may have been raced.
http://www.momentumjaguar.com/used/L...29e05d5834.htm
At quick glance, looks like it could be a good deal. Like it was said above, 100k miles is nothing for a Toyota. Im also starting to like the 12+ wheels better than 11
Yup, starting to see more and more 11+ ISF's in the high $20s
Not sure why they'd do a photo shoot in the dark.....a bit suspect. Def go check it out or either ask for much better pics.
And like stated above, 100k isn't many miles at all for this car, raced or not.
If it's in good shape, this is a good deal.
V.
V.
Funny that after the post and after your argument it comes out that the one you bought was right about $30k, and 95k miles and black... big difference between that and what the OP was after. Clean low mile USB....
Here is my quote from my post that started your pissing match and continued ill advising to people
"Only 2011's I see under $30K have at or more then 100k (97K-99k) miles, even then then, they're $27-30,000.00."
I still maintain BLKGHST, go find a USB 2011 with 65k miles for $27-28k..... STILL WAITING
I felt the same way about the photos in the dark. I will reach out to them and see if I can get some better ones.
The reason it didnt last was because they send it back to the auction. I went to check it out a week ago and it was already gone. The car had bolt ons and tune, since it didnt pass inspection the dealer didnt want to mess with it.
Why didn't it pass inspection? Should be zero Check Engine lights on with the tune. Of course, unless it wasn't exhaust/O2 sensor related.
V.
V.
it seems the mods where intake, header, exhaust and tune. Typical bolt ons.
The car has been tracked in its past for sure. The Carfax shows rotors replaced often and alignments often. Regular driving would not require brake rotors to be replaced that much. It was sent to the auction like was stated above. If it didn't pass inspection in TX is likely won't pass in CA. I'm going to pass on this one.
The car has been tracked in its past for sure. The Carfax shows rotors replaced often and alignments often. Regular driving would not require brake rotors to be replaced that much. It was sent to the auction like was stated above. If it didn't pass inspection in TX is likely won't pass in CA. Not sure what the issue was exactly but I was working with a sales guy and he told me the same thing that was stated above. I'm going to pass on this one.
What's the issue with a car that's been "tracked often"??? That's what this car was made for/designed to do.... And more times than not, the ones that are tracked often are the ones that are cared for and maintained better than the ones that aren't tracked, lol.
To each their own...
V.
V.
