Does anyone know where the jack points are?
Old 12-16-17, 01:25 PM
Cjl22
Cjl22's Avatar
Default Does anyone know where the jack points are?
I can see the rear one, but not sure of the front. (Center of vehicle jack point) thx. Picture would be great
golferjack (12-22-21)
Old 12-16-17, 01:28 PM
Elation
Elation's Avatar
It's in the owner's manual.
Old 12-16-17, 03:54 PM
sderman
sderman's Avatar
Yep. It's why I keep all of my manuals as pdfs on my PC. If I need to find anything I press Control + F. Entering just the word "jack" got me there almost immediately.
The following 2 users liked this post by sderman:
Elation (12-16-17), RaiderHawk (06-17-24)
Old 12-16-17, 04:00 PM
Cjl22
Cjl22's Avatar
got it thx.
Old 12-16-17, 04:19 PM
Elation
Elation's Avatar
I was wondering if they had one online.
Found it easily.
Canadian Lexus manuals
https://www.lexus.ca/lexus/en/owners/manuals
US - doesn't work for me, but you can try
http://drivers.lexus.com/lexusdriver...nuals-warranty
Old 12-16-17, 09:48 PM
Jiggz858
Jiggz858's Avatar
Might as well post the pics for others:
Jacking Points for 4RX350
The following 7 users liked this post by Jiggz858:
JeffKeryk (01-13-22), JerryRX350 (05-18-20), LRX05 (04-22-20), mjdgarage (06-23-23), nightdiff (08-16-21), PeeVee (12-18-17), ravenuer (12-17-17) and 2 others liked this post. (Show less...)
Old 12-17-17, 06:29 AM
sderman
sderman's Avatar
Found it easily.
Yes, I use the lower link for U.S. manuals.
Old 04-03-18, 12:37 PM
SoCalRX
SoCalRX's Avatar
Default Lift Points
Can someone with a service manual please post the diagram indicating the proper RX 4th Gen lift points? Thank you. I know where the floor jack approved points are and have used them (make sure you have a floor jack rated to lift the RX's weight).
Also a note to those considering installing running boards, you cannot use a floor jack with a pinch weld adapter as the running boards impede the head of the floor jack. You can still us the factory supplied scissors jack that comes with your RX.
Old 04-03-18, 02:11 PM
My450H
My450H's Avatar
I'm interested in all of this as well.
Decent floor jacks are expensive and taking up too much room, so I got a 20 Ton bottle jack that can lift up to 18". Is that OK to use? I know my rx weighs under 2.5 tons per google research.
I am planning to install running boards. I cannot picture what you mean by "cannot use a floor jack with a pinch weld adapter as the running boards impede the head of the floor jack." yet. Hope I get all the stuff correct when time comes.
Old 04-03-18, 05:45 PM
ravenuer
ravenuer's Avatar
The pinch welds are the jacking points under the rocker panels in back of the front wheels and in front of the back wheels. Running boards are mounted just below these points thereby precluding use of a floor jack. Hope that makes sense....!
Old 04-03-18, 07:26 PM
Jiggz858
Jiggz858's Avatar
Basically the lift points are the same as the jack points as shown:
Jack Points or Lift Points.
LRX05 (04-22-20)
Old 04-19-20, 09:56 AM
Blw2000
Blw2000's Avatar
Can I lift entire front/rear so that tires are off the ground from these points? I’m talking about the first picture showing the front and rear lift points.
Old 04-19-20, 11:14 AM
Quantum501
Quantum501's Avatar
The two points shown in Post #6 are the lift points for the entire front end (both tires off of the ground) and the entire back end. Then you can put jack stands at the side areas shown in Post #11 if you want your car elevated and level.
Old 04-19-20, 04:23 PM
arrowroot
arrowroot's Avatar
Wouldn't putting jack stands @ the pinch welds damage/bend the pinch welds?
Old 04-19-20, 04:44 PM
ravenuer
ravenuer's Avatar
No, because the pinch welds are designed to hold up the car.
Aeon (11-27-20)
Quick Reply: Does anyone know where the jack points are?
