Anyone know how to disable daytime running lights
Old 12-15-17, 09:22 AM
jdcrem00
jdcrem00's Avatar
Default Anyone know how to disable daytime running lights
I recently installed new headlights on my 08 ES 350 (OEM style) and I switched to LED low beams. The low beams have the "demon eye" feature which makes the low beams project a certain color when the headlights are not on. The daytime running lights ruin this look for me because they project a yellowish light out of the high beam, taking away the full effect of the "demon eyes". I have tried to take out the fuse for high beams, but I would like to be able to use them. I've tried to modify the wires to the high beam but that did not work. I'm looking for a way to shut off the daytime running lights. Does anyone know where the control module that controls them is located and which wire I should pull? A wiring diagram would also be helpful, Thank You.
Old 12-15-17, 10:00 AM
ESh
ESh's Avatar
Received 1,040 Likes on 774 Posts
You can turn them if you have Techstream, or if you visit your dealer.
jdcrem00 (12-15-17)
Old 12-15-17, 10:30 AM
jdcrem00
jdcrem00's Avatar
Thanks for the help!
Old 12-15-17, 10:39 AM
Htony
Htony's Avatar
Strictly speaking it is illegal to disable DRL. Also think safety.
Old 12-16-17, 03:32 AM
lgb0250
lgb0250's Avatar
Nope. Maybe where you live but definitely not everywhere.
Old 12-16-17, 04:35 AM
codejd
codejd's Avatar
The Carista app will allow you to do this.
Old 12-16-17, 11:42 AM
RA051724
RA051724's Avatar
It is definitely illegal in Canada, and likely some European countries, but its ok to disable DRL in the US. In fact, many cars meant for the US market actually provide a DRL disable button.
But I side with your safety comment..... not sure why anyone would want to disable it and prefer not to be seen!
Old 12-16-17, 12:07 PM
ESh
ESh's Avatar
If he disables the DRL that doesn’t mean he will not turn the low beams on.
I
Old 12-17-17, 10:00 AM
ThumperPup
ThumperPup's Avatar
In the united States it is not other wise everyone with a car that is any older than the 90s would be driving ileaggly
however perhaps in your area those cars could be under grandfather laws because if its over 25 years it doesnt have to abide by most emissions but still saftey is another thing so DRL would be considered a saftey essiue wich still wouldn't fall under those laws
Old 12-17-17, 11:20 AM
RA051724
RA051724's Avatar
I
Fair enough. I'm a bit memory challenged, so in my case I would rather rely on the electronics to do it every time.
On a different but related topic, have you seen those dopes who use their high beams during the day, thinking it doesn't blind others?
Old 12-17-17, 11:24 AM
Htony
Htony's Avatar
Origin of DRL is Scandinavia where winter is long. Many years their data shows accident rate dropped since DRL implementation. That is the reason it came to NA. Legality aside safety factor is involved.
"See and to be seen". .Personally safety factor over rides how the car I am driving looks. Cars in my family; MB, Audi, BMW. One Toyota 4 Runner. Had Lexus RX hybrid once.
Old 12-17-17, 04:29 PM
jagtoes
jagtoes's Avatar
I would try to get a wiring diagram and see how the DRL's function. They are on a lower voltage but I don't know if they work from a relay or if the voltage comes from the ECU. If a relay there would have to be a resistor lowering the voltage in the normal driving range and then switch to the higher voltage when the light switch is turned. If fed from the ECU then the voltage differential would be from the circuit..
Old 12-17-17, 04:49 PM
Htony
Htony's Avatar
One thing for sure is ECU is not in the business of supplying voltage(to go with current). It's job is sending control signal on various functions thru interface control network.. Relay could be also solid state relay nowadays.
Old 12-19-17, 05:08 AM
igzy
igzy's Avatar
In USA, the DRLs are not mandatory whereas in Canada they are...
On a side note, there should be a DRL relay. Removing it should disable them while leaving other headlight functions the same...
Old 12-19-17, 11:54 AM
jkayca
jkayca's Avatar
That is not strictly speaking true. While the vehicle must be equipped with DRLs if manufactured after 1989, it is not illegal to drive with them being disabled. I don't know about the rest of the world.
https://www.thestar.com/autos/2016/0...n-ontario.html
Quick Reply: Anyone know how to disable daytime running lights
