Replacing sub with Fogate P3
Old 10-22-17, 02:15 PM
MikeFoxx
MikeFoxx's Avatar
Default Replacing sub with Fogate P3
I can't take it any longer. I'm pulling the rear sub out and dropping in an 8 inch P3 dual 4 ohm sub today. Didn't want to repair the original or by oem to blow later. Wiring correctly for 8 ohm essentially a direct swap.
Old 10-22-17, 02:20 PM
Jabberwock
Jabberwock's Avatar
8 ohm rated sub should work OK. 12 or 16 ohm would be safer but harder to find. An 8 ohm sub will play louder. Be be careful with high volume - if you notice that the amp cut out or clip (blat or distorted sound) at higher volumes take it down a notch or risk bricking the sub channel.
Old 10-22-17, 05:49 PM
MikeFoxx
MikeFoxx's Avatar
Yessir this is just a temp replacement but def no need to play it loud anymore. Sounds so much better on low volumes or I should say lower than previous volumes. Replacing all the door speakers with Hertz and a 4 channel amp and then sometime early 2018 removing the rear deck sub and running a self enclosed ported DD sub in the trunk. This will hold me over till then. Still tweaking the factory settings but it's a nice noticeable difference over oem or the front heavy setting with the blown sub.
Been awhile since I posted a thread... nice to see some older folks are still around.
Old 10-23-17, 05:40 AM
lexman52
lexman52's Avatar
Can someone show me a step by step replace the sub. TY
Old 10-23-17, 07:27 AM
Romanova
Romanova's Avatar
Sure.
Or
Old 10-23-17, 08:01 AM
LOLjasonW
LOLjasonW's Avatar
im on the verge of having to do this and a few doors in my gs
Old 10-23-17, 09:23 AM
Zpat
Zpat's Avatar
Anyone tried, replacing the sub via the cover on the upper board?. I thought about pulling
it off, and in case, building a bigger cover... got the massage seats, not sure if i break anything
with the standard way.. (sorry for my austrian english)
I bought a "audiotec Fischer PP8W-Q" with 4 x 3 ohms, qts 0,51
(probably not available in the US)
Thanks!
triniexr
07-11-14 10:58 AM
lukeisf
IS F (2008-2014)
01-31-11 03:18 PM
Xeeeeeem
12
04-20-07 02:53 PM
spxChrome
31
04-15-03 08:31 AM
Quick Reply: Replacing sub with Fogate P3
