CT 200h Model (2011-2017)
Change Passenger Side Low Beam Bulb
Old 10-19-17, 07:04 PM
professorn
professorn's Avatar
Default Change Passenger Side Low Beam Bulb
I'm sure there's a better way to do this, but I tried reaching into the cramped area on the passenger side to get to the low beam to replace a dead bulb. I can't get it out as I can only get 1 hand in there. What is the correct way to do it?
Old 10-20-17, 12:09 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
I only used one hand to change out the bulb. Just reach down there and turn it. Give it a tug and the bulb will come out.
Old 10-20-17, 10:57 AM
xis
xis's Avatar
easy peasy. Just twist and yank. I just did it and changed out the low beam halogens to LED for a YUGE improvement
Old 10-21-17, 07:43 PM
lexusrus
lexusrus's Avatar
It's just a little difficult if you have big hands.
I replaced with a FAN LESS HIGH POWERED LED bulb. All good.
I also replaced the fogs with the same type LED bulbs. The 2013 CT200h uses the same low beam and fog bulbs. It's more involved with fog light replacement bc you have to remove the wheel liners PARTIALLY. NO need to take the wheel off, just turn the steering wheel to the opposite side of you are working on.
Wear some gloves (nitrile).....so you don't get any skin oil on the new bulbs.
Old 10-23-17, 08:04 AM
Dirteeboy
Dirteeboy's Avatar
You may have to move the black intake hose (2 clips) and the coolant neck (couple screws or clips). I had to move these guys to get the HID bulb and wiring in
boobobo
01-20-17 11:55 AM
dmanwi
12-28-16 08:24 PM
BISnTRIS
10-02-14 04:48 PM
KevMMA
Lighting
10-03-08 02:55 PM
dRo15
01-12-08 05:31 PM
Quick Reply: Change Passenger Side Low Beam Bulb
