what's the widest wheels and offset have fit on the RCF
Old 10-18-17, 04:37 PM
RC5
RC5's Avatar
Default what's the widest wheels and offset have fit on the RCF
Dear all fellow RCF owners here,
just the simple question again about wheel fitments. what's the best width and offsets of the wheels will fit on the RCF? looking to keep it in 19" as don't wanna go too low profile.
Old 10-18-17, 04:53 PM
GetKinetic
GetKinetic's Avatar
Queue the "use search" responses in 3...2...1...
RCFCoop (04-15-19)
Old 10-18-17, 04:56 PM
GetKinetic
GetKinetic's Avatar
For whats its worth. Im looking at a 9.5x19 front with a 35ish offset. And 10.5x19 rears with a low 30s offset.
this will allow for me to run 265 upfront and 295 or 305 in the rear
Old 10-18-17, 05:15 PM
RC5
RC5's Avatar
cool just wanna know as im getting a set of wheels 19x9.5 35 offset front and 19x10.535 offset rear just see if it clears
will run 275/30 in the front better or just run 265s?
Old 10-18-17, 05:35 PM
GetKinetic
GetKinetic's Avatar
Those offsets should work well.
I dont think you need 275 upfront but Ill let others respond.
what will you put on the rears?
Old 10-18-17, 06:04 PM
RC5
RC5's Avatar
gonna run 295s on the rear. so just run 265/30 will do just fine yeah?
Old 10-18-17, 06:23 PM
GetKinetic
GetKinetic's Avatar
Why not 265/35?
Old 10-18-17, 06:31 PM
GetKinetic
GetKinetic's Avatar
no need to go 30 series when 35s give you more sidewall and are within 2percent of circumference
Old 10-18-17, 06:55 PM
Mingofish
Mingofish's Avatar
275/30 or 275/35 will fit on the front with a +35 rim w/o scrubbing issues.
I’ve tried both. As long as car is not unusually low. A fender to ground measurement of 25.5-26” and it will clear.
265 tire on a 9.5” rim will look a bit stretched. Better on a 9” rim. But it will bead up fine.
275/30 will give a more square side wall and look better imo.
Guess it depends on the look you want.
275/30 taller than oem 255/35 but it’s close enough.
295 on 10.5 rim is perfect. Almost exact diameter as the oem 275/35
305 even better looking although I’ve never ran them myself.
If you have oem suspension, it may rub? Check with the 305 club...
I think with coilovers 305 shouldn’t rub at +35
Old 10-18-17, 07:16 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Actually not true.
However, a 295/30/19 tire is the same OD as a 255/35/19 tire.
Lou
Attached Thumbnails what's the widest wheels and offset have fit on the RCF-tinygrab-screen-shot-10-18-17-7.15.03-pm.png
Old 10-18-17, 08:14 PM
RC5
RC5's Avatar
thanks for the info, im not a stretch fan i like the chunky square look more but just afraid will rub if running that width.
im happy with 295s at the rear 305 is just bit too much imo
Old 10-18-17, 08:43 PM
pheen619
pheen619's Avatar
I'm running 19x10.5 with 305's in the rear. No issues.
Old 10-18-17, 10:37 PM
lexusrus
lexusrus's Avatar
Where to go for the time sizing chart please?
How about 265/35/19 (front) and 285/35/19 (rear) ON STOCK WHEELS with Micheline PS AS 3+?
THANKS
Old 10-18-17, 10:49 PM
flowrider
flowrider's Avatar
^^^^No need to use a calculator IMHO. Just go to the Tire Rack WebSite choose a size than a tire. You get the exact dimensions of the tire of your choice. See attachment.
Lou
Attached Thumbnails what's the widest wheels and offset have fit on the RCF-tinygrab-screen-shot-10-18-17-10.46.18-pm.png
Old 10-18-17, 10:59 PM
lexusrus
lexusrus's Avatar
Thanks.
Looks like my proposed set up will work.
Lou
Quick Reply: what's the widest wheels and offset have fit on the RCF
