Mirrortap into 2017 IS 300 for radar detector
I want to connect my radar detector to the power in the rear view mirror. I have seen people post pictures of their wiring harness showing which color wire is the power ignition and ground. All seem slightly different than mine. Does anyone know the setup for my car? Its a 2017 is 300. The available color wires are white, light green, blue, and 2 pinks.
Any help would be great.
Received 1,732 Likes
Picture is worth a thousand words - The 2 pink are not both pink...ones violet, but pretty close to pink
I want to do this what radar detector did you use?
I try to install the mirror tap i had laying around for the longest, Open up the cover and notice the white harness is a bit different then yours. My blue wire is first then purple. So i try both way power&ground and switched it up, but nothing works. what gives? I try to push the prongs down as much as it can go.
To clarify, depending on the specific year of 3IS you have, the color of the Ignition and Ground wires may be different .
However, no matter the color of wire in the position of the connector, the Ignition wire is still the Ignition wire, and the Ground wire is still the Ground wire.
The Ignition wire can be either Pink, Purple, or Blue depending on the year.
The Ground wire can be Purple or Blue, depending on the year.
shirosan (08-15-18)
It's not specific to the model of IS...it would be the same for a 250/300/200t/350 of the same year.
I can't remember exactly what year, but for sure it's not a 2017 or 2016...it's either a '14 or '15.
Regardless of the color, pin 1 is the Ignition and pin 2 is the Ground...that did not change over the years and models of 3IS.
zhifan1 (11-28-18)
My setup
Of the 2 pink wires I had...I tried the one closer to the blue...and I guess it would be position 1...that Ended up being the ignition power. The blue wire (position 2) was the ground.
How it looks mounted in my 2017 is 300
So my power ignition was the pink wire and ground was blue.
DrHorrible
08-06-15 01:21 PM
upstateGS4
08-07-10 08:34 PM
