hey guys quick question. I just notice this, under where the fuse box on the driver side is next to the OBD port what is that button that says "SET" ? and next to it i have a empty slot am i missing something there?
car is a 2014 is350 f sport.
Do you have TPMS? i think its for setting the low tire PSI range.
Yep i have TPMS. i see so pretty much is this how it works? put the amount of psi in the tires then click the set button once it falls below that it would alert you on the dash?
and as for the other slot next to it am i missing something? or its suppose to be blank?
upload a picture so i can see.
TPMS, hold the button and when it goes under a certain value ( i think its like 10 psi? under what you pushed the button at) there will be a warning.
