91 LS400 Issues. Similar To Celsior But NOT
Old 10-17-17, 08:41 PM
Moarpower
Moarpower's Avatar
Exclamation 91 LS400 RPM And IDLE Issues.
Hi guys. I just fixed an Idle and misfire on my celsior and It is getting ready to be turbod, Just finished fabbing the exhaust. I have 1991 LS400 that is running, as a parts car but I think I am going to fix it and sell it as I really dont need it. Its in pretty good shape, 180k kms. I was hoping it would be the same issue as my Celsior as it appeared, however, the same fix did not work.
It seems to be misfiring after it warms up. Start up is fine, a little white smoke at times and it idles and revs pretty much great, maybe a tiny bit rough. But the longer it runs the worse the idle and running becomes. Its almost as tho it is cutting out for a split second but it keeps running and doesnt stall. No CEL, No codes. I replaced both O2 sensors and the Coolant temp sensor will be here today. I thought it was the coils so I swapped them with the ones I just replaced on the celsior, no good.
I had a spare working ECU but sold it so I have ordered the correct Caps to do the ecu repair. On inspection the caps seem fine. I also tried the same ecu ripple test as I did on the Celsior but it doesnt have the same diagnostic ports.
There seems to be a PS leak which I will investigate further
Any other ideas while Im waiting for the sensor and capacitors?
EDIT- Also replaced thew spark plugs. Have not done wires yet.
Old 10-17-17, 11:26 PM
Moarpower
Moarpower's Avatar
Sorry. By caps I mean capacitor. There's and rotors on the other hand could also be at fault. I also have not replaced the leads but the resistance is is all good on them. Not to say that when they headed they don't have issues.
Old 10-18-17, 05:54 PM
Moarpower
Moarpower's Avatar
Ordered timing belt kit, caps and rotors. I'll check the car after each is replaced to try to identify the cause
Old 10-18-17, 09:24 PM
Moarpower
Moarpower's Avatar
Replaced the original ect sensor, which crumbled to pieces in my hand. Notices the previous person enjoyed using water as coolant .
Old 10-18-17, 09:44 PM
Moarpower
Moarpower's Avatar
The old sensor
Old 10-18-17, 10:08 PM
Moarpower
Moarpower's Avatar
No change after sensor. Will leave it for a few days until caps, rotors and coils arrive.the timing belt kit is on backorder. As are the leads
Old 10-22-17, 09:38 PM
Moarpower
Moarpower's Avatar
Removed the 10 old caps. All of them seemed fine, no sign of leaks or issues
Replacing the capacitors did not fix this issue. As I suspected it is either a spark or injector issue.
Old 10-23-17, 01:01 AM
Moarpower
Moarpower's Avatar
Cap and rotor set along with coils should be here by wednesday. In the meantime I will double check grounds, relays, sensors and plugs. It could be a right bank injector, however the issue is not in consistent timing, its more like random Morse code beeps where the revs stutter.
Old 10-25-17, 11:47 AM
RA40
RA40's Avatar
Very thorough Waiting to see what the outcome is with the new caps installed.
Old 10-25-17, 04:20 PM
Moarpower
Moarpower's Avatar
Cap and rotors are due for delivery today! However the coils have been delayed til, worst case scenario, next Tuesday.
NOTE- I would usually not approach the issue this way. Its always better to diagnose and eliminate all possible non issues before throwing money at any car. However, in this case all these parts were going to be replaced anyway. At this point I am unsure as to which car to keep as my main project.
Old 10-25-17, 06:38 PM
Moarpower
Moarpower's Avatar
First part of todays deliveries. Caps are due shortly.
Old 10-25-17, 06:40 PM
Moarpower
Moarpower's Avatar
Might as well plug the guy. Good service and prices lower than dealer for oem
Old 10-25-17, 07:26 PM
Moarpower
Moarpower's Avatar
Looks like the right cam has advanced a tooth! What do you guys think?
Old 10-25-17, 07:29 PM
Moarpower
Moarpower's Avatar
Left and crank centered
Definately forward on the mark. We may have found our perp
Old 10-25-17, 07:32 PM
Moarpower
Moarpower's Avatar
Quick Reply: 91 LS400 Issues. Similar To Celsior But NOT
