Reverse lights not working, all other lights work..
Old 10-17-17, 06:17 PM
ihateu3
ihateu3's Avatar
Default Reverse lights not working, all other lights work..
As stated, all other lights in the car work, but neither reverse light does, and bulbs are fine. This leads me to believe that it is the reverse switch, but I cannot find any information on where the switch is located, or any wiring diagrams for it. Does anyone have a location for the switch and or wiring diagrams for it?
Old 10-18-17, 05:31 AM
jr4div2
jr4div2's Avatar
Do you have Nav? Does the camera show up when you put the car in reverse? I'd look for a fuse before I go tearing into the console to find the reverse switch.
Old 10-18-17, 07:39 AM
ihateu3
ihateu3's Avatar
No nav and no rear shade (also relies on reverse switch)... I am not sure of any fuse for only the reverse lights, I do not think that they are on a circuit by themselves, but I would love to find out otherwise.
Old 10-19-17, 04:09 PM
sktn77a
sktn77a's Avatar
Pretty certain to be the switch. Usually located right by the gear select lever (under the center console).
Old 10-20-17, 06:12 PM
ihateu3
ihateu3's Avatar
There is a switch in the console? I just guessed the backup switch is on the transmission.. is there another switch in the console?
Old 10-21-17, 02:11 PM
2013FSport
2013FSport's Avatar
Received 1,482 Likes on 1,236 Posts
Switch is on the A760 trans.
Just me but with a meter verify the bulbs do in fact have a path ti ground. So basically ohm between an unpainted chassis bolt and one of wires that should be ground. Could be any color but if a black wire exists, its likely the ground.
If you have a 12V test light these work great too as they draw current which a meter doesn't. But now you need to supply 12v.
Also for $15 you get a 48hr pass on the toyota tis website to download schematics and troubleshooting tips. You might start there.
Old 10-21-17, 02:53 PM
mcomer
mcomer's Avatar
What model and year and transmission would you like?
We are in 2006 - 2013 IS but your profile mentions 1999 GS...
Old 10-21-17, 10:58 PM
ihateu3
ihateu3's Avatar
Ok, that is a good idea, and I will check the ground just to make sure, but I failed to mention that also the "R" does not light up on the dash either when in reverse, so either the bulb is coincidentally blown out, or it does not know it is in reverse. Not sure how far down the line that "R" goes.
Old 10-21-17, 11:12 PM
ihateu3
ihateu3's Avatar
2008 IS350, automatic. I do own a 99 GS300 as well, guess I need to update my profile to include the IS350.
Old 10-22-17, 11:29 AM
2013FSport
2013FSport's Avatar
You may not know the answer but has the trans been replaced?
On every trans with a case mounted switch you **almost always** place the trans in Neutral and insert a small gauge wire or maybe a drill bit through a hole in the switch and it drops in. It is doesnt, loosen the switch, rotate it until it does. Tighten switch and adjust linkage so park, neutral and drive align inside at the console.
Make certain vehicle will not move if you get under it and yank it out of park! It'll run you over!!!
Old 10-27-17, 07:59 PM
ihateu3
ihateu3's Avatar
I have tried working on this, but it seems no matter how hard I try, I cannot easily get to the reverse switch on the tranny to test the switch. I think I am really going to have to get it up on a lift to get to it..
Old 02-05-20, 05:15 PM
GPOM
GPOM's Avatar
Default RX350 Reverse Light Fuse
On my 2010 RX 350 there is a stand-alone fuse #36, BK/UP 7.5 amps, located in the fuse panel under the hood. A different 10amp fuse operates the other rear and side lights, located in the interior fuse panel below the steering wheel, Tail #22.
GPOM
Old 02-07-20, 08:20 AM
2013FSport
2013FSport's Avatar
Default Ihate is gone.... car wrecked
GPOM
Thanks for the info.... Guy is gone. Car wrecked. Maybe this will help another....
Old 06-24-22, 05:44 PM
ejdossary
ejdossary's Avatar
The manual does show Fuse #36 is the Backup lights fuse. if the two light do not work, then it could be a fuse, Revere Switch, or the Relay. I have 2012 RX350 and experiencing the same issues. I will have to troubleshoot and find which is causing the problem ! Once I find the fix, I will report to the CLUB !! EJ Dossary, EE
Ginsedwar
12-16-18 11:09 AM
techrep
GX - 1st Gen (2004-2009)
05-12-15 08:00 PM
theviola92
RC - 1st Gen (2015-present)
03-30-15 02:57 PM
mattattack
08-06-14 08:35 PM
dtLS400
12-29-11 11:59 PM
Quick Reply: Reverse lights not working, all other lights work..
