07 is250 plz help
Old 10-17-17, 04:41 PM
Bbob250
Bbob250's Avatar
Default 07 is250 plz help
I change the alternator today on 2007 is250 and this is what I get,the car will not run
Old 10-17-17, 06:04 PM
whitebeast
whitebeast's Avatar
Check the connector between the A/C compressor and exhaust manifold (as i remember). You may damaged the connector during moving the wiring for clearance
Old 10-18-17, 04:10 AM
Bbob250
Bbob250's Avatar
I saw so many different pictures of Cam sensors yesterday I I wasn’t positive that little plug in between the compressor was the crank position sensor thank you for the help I will Tell you how it goes
Old 10-18-17, 11:04 AM
Gville350
Gville350's Avatar
Agreed, double-check your work. You probably accidentally pulled a wire out of a connector by accident.
Old 10-18-17, 12:55 PM
Bbob250
Bbob250's Avatar
Default Junk
I have a 03 navigator And a 1995 Jeep The connectors on those cars I have no problems with and they’ve been through a lot more than this Lexus The connectors are cheap the wiring is cheap everything is crap very poor made car unless you keep in your head cars are meant to be taken to dealerships to be worked on I’m not impressed at all with how brittle the wiring and plastic was under the hood of the car it’s a 2007 Lexus I S250
Old 10-18-17, 12:56 PM
Bbob250
Bbob250's Avatar
I do want to say thank you for your help with this situation
jhuezo
01-28-18 07:46 AM
Clicky
03-16-17 04:56 PM
dkent
01-28-16 02:29 PM
Rising2010
10-07-10 01:43 PM
Quick Reply: 07 is250 plz help
