Front camera installed
Old 10-16-17, 02:57 PM
antnguyen
antnguyen's Avatar
Default Front camera installed
Hey everyone,
Just wanted to show a cool DIY project that will help protect your front bumper/lip while parking. I've scraped/hit a curb a few times while parking so I wanted a way to prevent that from happening again. Basically I installed a small camera to my front lower grill and wired the video feed to the OEM navigation unit. I can turn on the video feed whenever (while driving/reversing/park) by the push of a button. And I still have the original functionality of the rear camera. The parts costed me about $50 and took about 6 hours to complete.
If anyone is interested I can write up a DIY, but unfortunately I didn't take pictures during the install process, so I would only be able to provide instructions, parts needed, and a wiring diagram.
Front camera video feed on the OEM nav unit:
Switch("Driving Lights") to activate front camera:
Picture of the camera installed on my lower grill (and my already destroyed bumper lip):
Parts needed:
- Backup camera. Get one which does not reverse the image. I used
https://www.amazon.com/gp/product/B074M7FBZN/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B074M7FBZN/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
- 12V DC Relay switch DPDT. I used
https://www.amazon.com/NTE-Electronics-R14-11D10-12-General-Arrangement/dp/B000P9ICN8/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1508207721&sr=1-1-catcorr&keywords=nte+dpdt+12 https://www.amazon.com/NTE-Electronics-R14-11D10-12-General-Arrangement/dp/B000P9ICN8/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1508207721&sr=1-1-catcorr&keywords=nte+dpdt+12
- Add-a-fuse
- Switch that fits in the blank switch compartment (left side of steering wheel). I used http://www.ebay.com/itm/MICTUNING-12...53.m2749.l2649
- Electrical wiring, wire nuts/connectors, wire taps, etc
Wiring diagram:
Rough instructions (For 2009 ISF, not sure if other model years have the same nav unit)
1. Get access to back of navigation unit. I followed the steps in thread https://www.clublexus.com/forums/is-...le-moving.html
2. Cut the blue wire on connector J50 pin 13. Make sure not to cut too short on either side as you will have to tap into these wires. This is a 12v signal wire coming from the shifter assembly that tells the nav unit to switch input to camera view. The signal is active when the car is in reverse. See https://www.clublexus.com/forums/is-...ml#post2153467
3. Cut the red wire on connector J51 pin 27. Again, make sure not to cut too short on either side as you will have to tap into these wires.This is the video signal feed coming from the rear camera. See https://www.clublexus.com/forums/is-...ow-to-diy.html
4. Re-route these wires to the relay switch and wire up according to diagram. I placed my relay switch and all wiring in the compartment under the steering wheel, next to the fuse box.
5. Run the front camera video input and power wires from through the firewall out to the engine bay. The firewall is under the steering wheel and you'll see a bundle of wires going through it from the engine bay. I used a straightened wire coat hanger and taped the cables to it and forced it through the firewall into the engine-bay.
Notes: I used add-a-fuse on the mirror heater fuse. This is a 15 amp fuse that is always on. I haven't taken the time to find a fuse that is only on with ignition. I grounded all my wires to a bolt connected to the chassis. If you dig under the carpet next to the driver's side door-sill, you should find a bolt where there are other ground connections made to it.
The following 21 users liked this post by antnguyen:
2URGSE (01-11-19), Allan1 (10-21-17), Arein (01-17-20), Bigjon3475 (12-06-17), Boomin (01-30-18), Eurofreak (02-08-18), flowrider (10-16-17), Hughhtt (08-16-20), imp0rted1 (10-19-17), jadeboy (10-17-17), JKweezy (10-19-17), John12ISF (07-30-18), JohnMorgan (08-15-18), kbtoiz (10-17-17), LexusfanVA (10-17-17), LexusNN (12-07-17), lobuxracer (07-27-18), mikersoft (10-17-17), NSXGuy (10-17-17), photomaker (11-16-17), Quadrphnia (10-20-17) and 16 others liked this post. (Show less...)
Old 10-16-17, 03:03 PM
mahcah
mahcah's Avatar
Nice work on that. Many of use would be interested in the parts used and what wires you connected to.
Old 10-16-17, 04:50 PM
F Monster
F Monster's Avatar
That's pretty cool! I'd love to see a guide for it!
Old 10-16-17, 05:58 PM
aznpg
aznpg's Avatar
better post the write up before you have a lot of people asking for it hahaha
Old 10-16-17, 06:07 PM
CarterIS
CarterIS's Avatar
Definitely interested in a parts list, especially the camera used; the quality looks great. I was going to tackle this back in 2016, but had trouble finding a good quality camera.
Old 10-16-17, 08:03 PM
antnguyen
antnguyen's Avatar
Alright, seems like a couple people were interested so I updated the original post with a brief DIY
The following 2 users liked this post by antnguyen:
DaveGS4 (11-11-17), lobuxracer (07-27-18)
Old 10-17-17, 05:52 AM
j3ff
j3ff's Avatar
Nice work man! Very clean OEM finish as well. My highlander has a front camera and it looks and mounts just like yours.
Old 10-17-17, 09:15 AM
LexusfanVA
LexusfanVA's Avatar
This is awesome man, great addition to the forum!
Old 10-17-17, 10:22 AM
mk416
mk416's Avatar
Ingenuity for sure. Thanks for the write-up!
Old 10-17-17, 05:28 PM
antnguyen
antnguyen's Avatar
No problem. It's definitely a fun little weekend project.
Old 10-18-17, 03:27 PM
Rickna
Rickna's Avatar
Good job indeed Good write-up
Old 10-18-17, 06:15 PM
CarterIS
CarterIS's Avatar
Great write up, very much appreciated.
unfortunately the link to the camera is unavailable. Do you know the model #?
Old 10-18-17, 06:42 PM
antnguyen
antnguyen's Avatar
The name on amazon is SVTCAM Multi-functional Car Rear View / Front View Backup Camera & Metal Housing Camera
Old 10-18-17, 10:20 PM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Took a screen shot for you.
Lou
Attached Thumbnails Front camera installed-tinygrab-screen-shot-10-18-17-10.19.36-pm.png
Old 10-19-17, 03:37 PM
CarterIS
CarterIS's Avatar
Thanks, used the name to search it up. Ordered and on the way.
Thanks Lou
Quick Reply: Front camera installed
