Positive Battery Terminal corroded
10th Gear
so my RX started having issues starting and I took a look under the hood and found the positive terminal was completely corroded. I started to disconnect it so I can clean it but it was gone to far and it broke off, whats my best option in fixing it myself? Do the cables need to be replaced?
Get a generic battery terminal from your local auto part stores and replace it yourself. I got the (that also fits most Japanese cars) and put it on my Toyota cars .. you might want to keep the original bolt/nut on your car to connect to the existing battery cable ... don't forget to coat the battery posts & connectors with silicon grease to prevent corrosion ...
Hyundai/Kia battery terminal set that also fits most Japanese cars ...
tehsu (10-16-17)
Well, you should have greased post and terminal inside with dielectric grease, set terminal all the way down to the battery top, driven screw at the angle in through the terminal(clamp) into the post to prevent upward self migration from vibration and sprayed over with battery terminal protector, purple stuff. THEN your terminal will NEVER corrode.
Just saying.
Just saying.
tehsu (10-16-17)
10th Gear
Just saying.
Just saying.
Good advice, I will be going back over it to do so, just took a long time to get the parts. Thanks.
Battery terminal
Cable corrosion. I've also had that problem however it wasn't an RV but the and the cable was outside water climbed from the battery all the way about 6 ft up the wire so check for water just saying there are other reasons for corrosion that you could follow to all them steps them guys are telling you the right thing to do but they're all so is this one other thing it's called water it goes up wires just saying
new_berlin
HS 250h Model (2010-2012)
12-18-17 10:13 AM
dxerg3770
ES - 6th Gen (2013-2018)
46
03-15-15 08:16 AM
