Front End Squeaking
Old 10-14-17, 05:42 PM
AlDavison
AlDavison's Avatar
Default Front End Squeaking
I did a search, but nothing exist like what I'm experiencing. My front suspension is squeaking like someone is jumping on a spring mattress.
It makes sounds on bumps only. Any ideals?
-Al
Old 10-14-17, 06:39 PM
XxGoKoUxX
XxGoKoUxX's Avatar
might be your ball joints going out. could be something else too, our suspension has a lot of parts. I would go under there and lubricate one thing at a time with something like WD40 or grease to see where the problem is coming from.
Old 10-15-17, 04:26 AM
AlDavison
AlDavison's Avatar
Post
Ok, but the ball joints boot is too tight. I can't get WD-40 in there. I'll try other places as well, but the sway bar bushing looks torn-up.
I see A-frame bushings as well. You're right! A lot of stuff is happing under there...
Old 10-15-17, 11:39 AM
RXGS
RXGS's Avatar
If the sway bar bushing is visibly deteriorating go with that first, it’s the cheapest and easiest thing to replace
Old 10-15-17, 11:49 AM
TRD_Power
TRD_Power's Avatar
Likely your sway bar bushings, especially if you see them deteriorating. Mine were creaking a ton whenever I'd drive over uneven surfaces at slow speeds. Greased them up and haven't had any issues the past 8 months or so.
Old 10-15-17, 03:03 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Let us know the results! It's always good to have resolutions to these problems for our future members
igrip (10-06-21)
Old 10-15-17, 05:17 PM
AlDavison
AlDavison's Avatar
Thumbs up
Ok. I will do one bushing and ball joints at a time.
Old 10-16-17, 05:42 AM
ibidu1
ibidu1's Avatar
I have a squeak coming from my top control arm ball joint, but yours maybe different. If you have a gopro you can mount that inside the wheel well pointing at the suspension and video a small drive with it recording and you can post that on here and so we can better help you out.
Old 10-16-17, 04:09 PM
AlDavison
AlDavison's Avatar
It's coming from the sway bar bushings. I can hear clearly from the bushing but the video does not show well from my iPhone. It's too dark down there, but I can hear it and I can see it move at the same time when I push down on the car from the hood. I put some WD-40 around it and that help a little, but some of the sound is still there: not much though...
File Type: mov
Old 10-17-17, 05:18 AM
ibidu1
ibidu1's Avatar
Swaybars do not travel/move for that length of squeak, im thinking maybe its lower control arm bushing. Might as well spray them with wd40 (to clean them) and lube them with white lithium grease spray
Old 10-17-17, 05:55 AM
AlDavison
AlDavison's Avatar
It's coming from this right here. What is this call? Thanks!
Old 10-17-17, 07:11 AM
ibidu1
ibidu1's Avatar
Yup thats the sway bar/stabilizer bushing! Grease it up! If the noise keeps coming back you may want to replace it, as it looks a bit worn. Good thing that part is pretty cheap and easy to replace.
Old 10-17-17, 07:45 AM
AlDavison
AlDavison's Avatar
I can't find a DIY for sway bar bushing. Should the wheels be on a car ramp or jacked-up?
Old 10-17-17, 08:16 AM
ibidu1
ibidu1's Avatar
You should be able to leave the wheels on, jack up the car put it on jackstands. Make sure both wheels are hanging freely, and then you might have to undo the lower plastic tray to reach the two bolts that hold the swaybar bushing clamp on. Simply unbolt both sides, the bushings usually have a slit cut in them to easily remove and install. But before you install the new bushing clean the parts and lube with a grease. Super easy!
diamente
06-25-18 10:28 AM
kikcaffine
Suspension and Brakes
24
04-10-18 11:39 AM
Agent$mith
13
05-26-15 07:42 PM
Jeffrimerm
05-18-15 10:43 AM
Alexbenz
10-13-14 10:26 AM
Quick Reply: Front End Squeaking
