VSC Light on
Old 09-28-17, 09:33 AM
Kazp
Kazp's Avatar
Default VSC Light on
Hi
I have a problem with my Lexus is 250 2008r lift.
My problem is with the VSC light on.The problem is strange, the computer does not show errors.
VSC light most often lights up when the car is hot in the middle of the sun.
It also happens that there is light at the first start of the engine when the stairs are in traffic, or the car goes without slipping wheels
The VSC light resets when I turn off the engine, but after a few minutes or kilometers, the light will be able to appear again
ABS works, I have not noticed the bad effects of VSC light. In addition to being annoyed and wanting to solve the problem.
Same VSC light, no check engine.
I replaced the gas cap, but that did not help
The dealer checked the active test and all the parameters are ok.
What could happen, someone had a similar problem?
Sorry for my english.
Old 09-28-17, 09:50 AM
mandyfig
mandyfig's Avatar
VSC is Variable Stability Control.
Do a search on Google.
Good luck.
Old 09-28-17, 10:15 AM
Kazp
Kazp's Avatar
In my case, the VSC does not Blink. It only lights up permanently
I know what is VSC....
Google
The VSC warning means nothing -- VSC shuts off due to any of a plethora of causes with most having nothing to do with VSC. Maybe the purpose of of the VSC warnings is to our attention. I've had the VSC warning on my LS probably four or five times including when the car was still under it's basic warranty and not once was there a problem with VSC.
Forum Lexus UK.
I can't find more information about my problem. That is the light-up VSC without cause
Old 09-28-17, 10:22 AM
MikeFig82
MikeFig82's Avatar
It’s probably one of the wheel speed sensors going bad. If you can get a scanner with ABS function. It will let you see which one is bad.
Old 09-28-17, 10:24 AM
Kazp
Kazp's Avatar
The problem is that all ABS sensors show the same speed of the wheels and the scanner does not show ABS errors
Old 09-28-17, 10:29 AM
MikeFig82
MikeFig82's Avatar
If your mechanically inclined. Pull the wheels off, and remove each one from where it’s mounted. They could have metal shaving build up. Also while your at it check resistance with an OHM meter. You’ll have to disconnect the harness from the frame to check both pins.
Old 09-28-17, 10:41 AM
Kazp
Kazp's Avatar
ok, i will try to check the ABS electric bundle.
Without the VSC light on the dashboard - it will measure good?.
Wait until the VSC light appears and use the OHM meter?
Old 09-28-17, 11:00 AM
MikeFig82
MikeFig82's Avatar
The ABS meter should indicating which side is bad.
Kazp (09-28-17)
Old 09-28-17, 11:11 AM
Kazp
Kazp's Avatar
Problem with ABS sensor should be constant?
In addition, the problem with ABS should rather show ABS light + VSC light all time on the dash.
My VSC light resets most often when the engine is shut down. After that, he will not light up until the end of the day
Thanks, I will try to do this test with a meter
Old 09-28-17, 11:25 AM
MikeFig82
MikeFig82's Avatar
Yes I’m sure it should be on always. Just the VSC light on is a little hard to diagnose, but the speed sensors are associated with that feature of the VSC. Like you mentioned in your first post about hot weather. Leads me to believe something is losing signal. Let us know what you find out.
Old 09-28-17, 11:33 AM
Kazp
Kazp's Avatar
If I solve the problem I will write it.
Old 10-15-17, 12:25 AM
Kikiwhanki
Kikiwhanki's Avatar
I agree with you on that one, a friend's IS250 once did that.
Old 10-16-17, 04:59 PM
Othic
Othic's Avatar
What scanner are you using? Its probably a Lexus specific code that a generic scanner will not pick up. Find out what the DTC is first.
Old 10-17-17, 06:46 PM
Rickii
Rickii's Avatar
Mine showed up as running rich in cylinder 1 when I scanned it.
i replaced my intake filter (which was filthy) and problem never came back up
Old 10-18-17, 08:58 AM
SebCypher
SebCypher's Avatar
My check system has always been on since Ive replaced my wheels. But now I have the VSC light on, I replaced the gas cap thinking it was too old. Just looking for a resolution.
landman
03-24-21 03:28 PM
Mikezim
02-02-19 05:34 AM
Mamba2481
01-14-19 12:13 PM
carmabite
GX - 1st Gen (2004-2009)
12
03-30-18 11:48 AM
ApoK
11-26-08 10:32 AM
Quick Reply: VSC Light on
