How Remove Factory OEM Spoiler
Old 09-23-17, 03:43 PM
toliphint
toliphint's Avatar
Default How Remove Factory OEM Spoiler
Have a 2014 ES350 with the factory flush mounted spoiler on the trunk. Need to replace it due to damage but can't get it off. Have removed trunk liner and what appear to be the only 4 bolts holding it on, but it won't budge. Is it also taped on? Are there more bolts, or clips? If so what is technique for removing it? Stuck, pardon the pun.
Thanks in advance!
Old 09-23-17, 04:04 PM
bc6152
bc6152's Avatar
Received 1,236 Likes on 868 Posts
Check out this link from a previous CL post. The photos are of an install but clearly show how it is mounted. There is double sided tape...
https://www.clublexus.com/forums/rc-...r-install.html
Old 09-23-17, 04:35 PM
Popgun
Popgun's Avatar
To get through the double sided tape, use dental floss or fishing line or some such and saw it back and forth to cut the tape. This method prevents damage to the paint. Clean up residue and reinstall when you are ready.
Old 09-23-17, 04:44 PM
toliphint
toliphint's Avatar
Thanks for your reply, but figured it out. Was able to pry up one corner ever so slightly and saw some "goo". So got out the hair dryer and plastic pry bars and Bingo! Spoiler off but not without a struggle. There is a layer of "goo" around the entire periphery of the spoiler despite its being held on with the 4 bolts. Must be to prevent water from running under the spoiler and attacking the seal around the spoiler studs . Pics attached of the "goo". And it's really tough. Thought I was going to break the spoiler pulling it up.Now soaking trunk with Goo Gone to remove goo. HTH someone else.
Attached Thumbnails How Remove Factory OEM Spoiler-20170923_182701.jpg   How Remove Factory OEM Spoiler-20170923_182708.jpg
Old 09-23-17, 06:18 PM
Popgun
Popgun's Avatar
Great job! Good to know its sealed good too (have one on my car).
Old 09-23-17, 07:57 PM
DanZ
DanZ's Avatar
Good job removing it. I have used Goo Gone on rear spoiler on another car. It does work but took three rounds. Try not to smell the Goo Gone since it has nasty solvents and work in an open area.
carlos93co
06-01-17 06:46 AM
mrk
08-06-13 02:23 PM
poorkidlol
12-22-10 10:33 AM
EthanV
04-13-09 09:42 PM
e-man
04-19-08 07:15 PM
Quick Reply: How Remove Factory OEM Spoiler
