2017 OEM tailpipes uneven
Old 09-23-17, 03:11 PM
FUZCO
FUZCO's Avatar
Default 2017 OEM tailpipes uneven
Hi everyone.
not sure if it was like this previously, but you can see from the picture below that the right exhaust tip is noticeable lower than the left. I did manage to lightly bottom out the left side exhaust end going up a steep driveway because I hit the gas too soon after clearing the front while turning right. Didn't even think it was possible le. All I heard was a light scrape noise and the saw a little scuff where the tip gasket connects to the muffler.
Is is it possible I messed up the alignment? I also see that the long pipes further down towards the middle of the car is positioned differently where the rubber band supports are. Not sure if this is normal.
I played around with both of the rubber band supports at the exhaust tip but it hasn't helped.
The odd thing is that the left exhaust tip looks like it's seated nicely whereas the unaffected right tip seems too low.
Any advice is appreciated!!!
Attached Thumbnails 2017 OEM tailpipes uneven-img_5423.jpg   2017 OEM tailpipes uneven-img_5427.jpg
Old 09-23-17, 09:19 PM
AMNss
AMNss's Avatar
I know its new car and you want everything to be as new, but the exhuast tips level difference is really not noticeable. I noticed it because you pointed out, otherwise I wouldn't know. You could little force the exhaust to the required position if it bothers you, but you have to watch out to avoid breaking the bands.
Old 09-24-17, 03:56 AM
ChineseKFC
ChineseKFC's Avatar
could it possibly be the rubber hangers that metal wire sticks through? check under the exhaust if some metal wires is sticking out
Old 09-24-17, 07:03 AM
volthause
volthause's Avatar
Not seeing it. Both your pics have the right side in shadow.
Old 09-24-17, 11:55 AM
otakusan
otakusan's Avatar
you can check and see if one of the tips was installed slightly tilted down
my 2016 which had oval tips had one of them slightly rotated, I just tapped and twisted it back straight.
Old 09-24-17, 01:35 PM
jmull3r
jmull3r's Avatar
i think they look normal... i swear i’ve seen ur car before where are you located in NJ?
Old 09-24-17, 04:35 PM
FUZCO
FUZCO's Avatar
Morris County, Parsippany area.
Old 09-24-17, 04:37 PM
FUZCO
FUZCO's Avatar
Just an update. After reading up on people having similar issues, a well concurred solution is use of zip ties. Are used for, two for each exhaust behind the rubber band hangers. They look much better now. I forgot to take pictures earlier I know it is dark out so I will take pictures tomorrow and post. Thank you.
NCNative
GS F (2016-present)
01-30-19 01:37 PM
ndk83
Performance
10-08-07 01:47 AM
gx470man
GX - 1st Gen (2004-2009)
09-25-07 02:23 PM
Scotty99
Performance
10-12-06 08:52 PM
imjohnphan
Performance
07-24-06 10:59 PM
Quick Reply: 2017 OEM tailpipes uneven
