NX - 1st Gen (2015-2021)
Is this engine noise normal?
Old 09-19-17, 09:42 PM
jdt
jdt's Avatar
Default Is this engine noise normal?
Hi all, I've been noticing a loud humming noise coming from my engine the past couple of days. I recorded a video and posted it below. Engine is already warm, ac and fan are off. Temperature outside was around 25 degrees celsius. Haven't had any issues with the engine so far but the noise is something new. It's quite loud and I can actually hear it when I'm inside the car. Much appreciated.
Old 09-20-17, 05:16 AM
SteveDeech
SteveDeech's Avatar
https://www.youtube.com/watch?v=pccVBV45nQc
Rather than posting this I would get right to the dealer before something serious happens if it hasn't already. That is not a normal noise. Did you check your oil level?
Old 09-20-17, 07:55 AM
skyshadow
skyshadow's Avatar
Agreed, that sounds much too like a diesel. You need to get to the dealer asap. Use Enform roadside and have it towed.
Better safe than sorry
Old 09-20-17, 09:31 AM
GoHuskers
GoHuskers's Avatar
Not normal at all. Please have it towed to the dealer and update us. Thanks.
Old 09-24-17, 07:41 AM
Lexusdk
Lexusdk's Avatar
All I have to say is "damn!". Who last serviced your vehicle? Sounds like engine doesn't have any oil in the crankcase.
Old 09-24-17, 08:28 AM
jdt
jdt's Avatar
Oil levels are fine and oil changes are up to date. Took it to the dealer the other day and mechanic said they are not sure what the noise is but will investigate further this coming week where I will bring the car in again and have them spend more time with it. Will keep you guys updated.
Old 09-26-17, 07:11 AM
Sheddy
Sheddy's Avatar
Your vacuum regulator needs replacing.
Vacuum Regulating Valve The Vacuum Regulating Valve (VRV) is a ECM duty cycled controlled device that limits the amount of vacuum going to the wastegate actuator. The VRV receives vacuum from the vacuum pump and check valve and provides this vacuum source to the wastegate actuator through vacuum lines in the system. During diagnosis of the turbocharger system, the VRV can be active tested. This active test is labeled as Wastegate Valve Control Duty Ratio.
The following 2 users liked this post by Sheddy:
5gears-IS (09-26-17), skyshadow (10-05-17)
Old 09-26-17, 10:06 AM
GS3Tek
GS3Tek's Avatar
Learned something new today. Thanks
Old 10-02-17, 04:57 PM
kent2174
kent2174's Avatar
Just started hearing this noise/hum/buzz.
Made appt at dealer this Wednesday.
Okay to drive if in fact it's VRV?
The sound not present when starting cold.
Old 11-20-17, 04:55 PM
vkliem21
vkliem21's Avatar
Yep. I had my VRV replaced, twice. I think its safe to drive, but get it replace ASAP, especially if it's under warranty. Took me a couple trips to the dealership to convince them there was an issue (unsual sound from the engine). The noise first started around 10K miles, and unfortunately, it came back again 10K miles later. So far so good, but I haven't hit my third 10K yet.
lexus114 (11-21-17)
ichitaka86
14
09-19-20 05:55 AM
Beef356
10-27-12 05:25 PM
sjgIS350
05-05-08 10:51 AM
animefreak
02-24-07 11:19 PM
Quick Reply: Is this engine noise normal?
