4 WIRE o2 Sensor to 1 Wire plug
Old 09-19-17, 01:43 AM
Moarpower
Moarpower's Avatar
Default 4 WIRE o2 Sensor to 1 Wire plug
hey guys. So i followed the intructions on lexls's site only to find that the o2 sensors on my car are 1 wire not 4! I purchased the ones linked and listed as the right ones for my car my they have 4 wires. Will I be able to just use the signal while and cancel the other 3?
Old 09-19-17, 05:50 PM
Yamae
Yamae's Avatar
No. You only can cancel 2 wires for the heater. Rest of 2 wires for the sensor should be used connecting the hot side to the O2 sensor line and the cold side to the engine body. It would be better to connect it to the E1 line of the ECU to minimize the interferences though.
Old 09-19-17, 05:57 PM
Moarpower
Moarpower's Avatar
Bummer. I was hoping to be able to use them on the pre cat sensors as they are only 1 wire and ground through the vehicle body.
if I ground the other wire somewhere on the body under the car should it work?
Old 09-19-17, 06:22 PM
Yamae
Yamae's Avatar
It works well if the impedance between the body and the E1 line is low enough. Actually I have used many 4 wires O2 sensors for many different cars which were installed 1 wire O2 sensors originally. Some showed better gas-mileage connecting the cold side to the ECU's signal ground line directly.
As you observe the signal of a single wire O2 sensor line using an oscilloscope at the ECU side, you can see quite a lot of noise from ignition, injectors and others. So it is a good chance to improve the engine performance to use a 2 wires (No heater but has a separate ground wire) or 4 wires one grounding the cold side directly to the ECU's signal ground.
Old 09-19-17, 06:59 PM
Moarpower
Moarpower's Avatar
Thanks mate. I will see how I go grounding them in that way. If I can't figure it out I will just find a good ground to the body
Old 09-20-17, 01:10 AM
Moarpower
Moarpower's Avatar
Any idea of how I could ground these to the ECU ground line?
tomer62
10-20-16 01:31 PM
unknown101
Performance & Maintenance
03-13-15 12:11 PM
-Future-
06-02-12 05:03 PM
carcass66
11-15-04 08:17 PM
Quick Reply: 4 WIRE o2 Sensor to 1 Wire plug
