I hate potholes
Old 09-18-17, 06:53 PM
ISFCOBRA
ISFCOBRA's Avatar
Default I hate potholes
Today I purchased a set for Firestone Indy 500 tires and purchased the lifetime warranty. During the alignment the tech mentioned he could properly align the right rear wheel. He had asked if i hit anything recently. I mentioned i hit a pothole during the recent storms. Well not sure what needs to be replaced but i will be taking this to the dealership to determine it.
Has anyone had a similar issue?
Old 09-18-17, 08:44 PM
mahcah
mahcah's Avatar
Partout. No. Maybe LCA?
Old 09-18-17, 08:45 PM
FFM
FFM's Avatar
Most likely one of these?
Old 09-18-17, 09:48 PM
2013FSport
2013FSport's Avatar
Received 1,482 Likes on 1,236 Posts
Now go get the left side to match! Set!
1.5° is a bit. Did you blow the tire or bend the rim?
Hopefully it's that ballpoint on the upper link.
Old 09-19-17, 08:51 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
Did they loosen all the bolts and check for obvious damage? The biggest issue is, if you hit something that hard, it's likely all the components are affected, not just the camber determining ones.
Old 09-19-17, 08:57 PM
ISFCOBRA
ISFCOBRA's Avatar
Rim was fine and did not blow a tire. Taking it to the dealership on Thursday to determine whats wrong.
Old 09-19-17, 09:00 PM
ISFCOBRA
ISFCOBRA's Avatar
No they did not and The only thing he mentioned was i may have bent the shock but he was unsure. It seems the tech did not want to touch it so i left with the car and will take it the dealership.
Old 09-19-17, 09:07 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
You can bend the shock until it won't move and it will make zero difference in alignment numbers as long as you are at spec ride height. This isn't a strut car. Mucking Forons working the alignment rack...
Old 09-19-17, 09:18 PM
ISFCOBRA
ISFCOBRA's Avatar
He had me worried after he said that.
thank you again
Old 09-21-17, 07:26 PM
ISFCOBRA
ISFCOBRA's Avatar
Well turned out to only be the alignment was off according the dealership. Car inspected and no issues found.
Old 09-21-17, 08:08 PM
FFM
FFM's Avatar
Wasn’t aware there was a factory camber adjustment?
Old 09-22-17, 11:23 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Nothing but toe is adjustable from the factory. If you want to alter camber or caster, you'll need to buy parts and replace the OEM pieces.
Old 09-23-17, 11:03 AM
FFM
FFM's Avatar
That’s what I thought. Somehow they “adjusted” out over a degree though haha.
dwoodsz79
10-21-17 02:59 PM
whatnext
11-05-14 05:27 AM
nato
Suspension and Brakes
05-25-10 07:07 PM
Percy
Maintenance
08-16-09 08:15 PM
panda327
01-29-09 06:07 AM
Quick Reply: I hate potholes
