4lo Flashing along with CEL
Old 09-09-17, 11:24 PM
Dallasguy1
Dallasguy1's Avatar
Default 4lo Flashing along with CEL
So today my wife told me some lights were flashing on the truck so it's 4LO along with CEL and Trac Off first thing I did was to check the gas cap coming from GX470 and I did hear a click sound after tightening it up. Truck is starting up and running fine no problems so is it the loose/bad gas cap or something else is wrong with it.
Dallasguy1 is offline
Old 09-10-17, 04:30 AM
Acrad
Acrad's Avatar
Received 3,562 Likes on 2,332 Posts
That kinda sounds like the secondary air control issue
https://www.clublexus.com/forums/gx-...50k-miles.html
Acrad is offline
Old 09-10-17, 06:14 AM
Jacket
Jacket's Avatar
Go have an auto parts pull the CEL code, then post up the details. Otherwise it could be a million things.
Jacket is offline
Old 09-10-17, 12:54 PM
Dallasguy1
Dallasguy1's Avatar
Got these codes from Carista.
Old 09-10-17, 12:59 PM
Acrad
Acrad's Avatar
That pretty much seals it being related to air control issue. That should be covered under that warranty enhancement.
Acrad is offline
Old 09-10-17, 01:14 PM
Dallasguy1
Dallasguy1's Avatar
Isn't it suppose to go in limp mode, it's driving fine with no problems. I'm thinking to replace the 15$ gas cap tomorrow and drive it around for few days and then see how it goes.
Old 09-10-17, 01:18 PM
tecman
tecman's Avatar
I didn't go into limp mode at first but eventually did.
tecman is offline
Acrad
Acrad's Avatar
I think so but not sure. I can't say I've seen loose gas cap show up with this error but anything is possible. If it does go into limp mode Tecman was able to confirm that if you disconnect the electrical connector on the air pump you will still get the CEL but no limp mode. That front front plastic cover comes up pretty easily... just lots of plastic panel clips to remove.
My fingers are crossed for you and hoping just gas cap.
Acrad is offline
Old 09-10-17, 01:51 PM
Dallasguy1
Dallasguy1's Avatar
I had the exact same problem on GX470 but the gas cap was really beaten up it being 8 years old but this one looks to be in pretty good shape just feels like loose, since I'm covered by the enhancement program I'll see how it goes ultimately it's the dealer. Btw shall I drive it around or don't take any chances.
Old 09-10-17, 01:58 PM
tecman
tecman's Avatar
Why not drive it? If it is the secondary air (and I do think so) you can reset to get out of limp mode with Carisa. I have reset the system while driving.
tecman is offline
Old 09-13-17, 07:24 PM
Dallasguy1
Dallasguy1's Avatar
So it looks like it is the secondary air problem and will take it to the dealer during this week. So do I tell them that I already know what is the problem and have received the letter for the Lexus enhancement program or just tell them to diagnose the check engine light.
Old 09-13-17, 07:34 PM
Dallasguy1
Dallasguy1's Avatar
I'm not getting this just looking around. Why is this soo cheap compared to the oem.
Old 09-14-17, 02:50 PM
Acrad
Acrad's Avatar
It could be that this is such a high failure item now ...the aftermarket it catching on. This is a fairly common failure on the Tundra forums for the 4.6 and 5.7L motors. There has to be a lot of them out there.
Acrad is offline
Old 09-14-17, 03:01 PM
tecman
tecman's Avatar
Sorry, I missed this. Either way they are going to scan the truck. You have nothing to hide.
tecman is offline
Old 09-14-17, 10:44 PM
Dallasguy1
Dallasguy1's Avatar
Have appointment on Monday as they didn't have a loaner available before that will keep you guys posted. Thx
Quick Reply: 4lo Flashing along with CEL
