Yet another Lexus Dealer overfilled Oil Change
I just got my my free 5K oil change at the dealer this morning. I had read about some people in the past having the oil overfilled so I got home and checked the dip stick. Looks like about 1 qt over filled just like everyone else has said. I wish I would have checked at the dealership. This is the first time anyone other than myself has changed the oil in one of my vehicles in over 10 years and now I remember why I always do it myself. So after spending an hour and a half at the dealership and now having to go back again, I should have just taken 45 minutes and done it at home like normal and just spent the $50 on parts.
The service writer at the dealership also mentioned at least 4 times they did all the service and blah blah blah including rotating the tires. I let that one go, clearly they have no idea what they are doing considering all F model and F Sport models have staggered tires that you don't rotate.
Just wanted to remind everyone to check the dip stick before you drive away from the dealership.
If happened countless times with RCF owners (3 times to me). Bet every RCF/GSF is overfilled since they all have the same instructions from the computer. It all comes down to laziness to check the dipstick. That's why before i leave the dealership, i walk around to make sure no damage and check the fluid levels
I took mine back to the dealer and they did take the oil back out and get it right to the top dot. At first the mechanic who did the service came over and was talking to the service writer saying something about, "O ya, we always over fill these engines a bit because it has an oil cooler and once it is running it is at the proper level." Sounds like so BS to me. I think I will take the Toyota engineer's advice in the owners manual, to get the engine up to normal operating temperature, shut it off, wait 5 minutes and then check the level on the dip stick rather than Jose the Lexus lube tech guy advice.
In the end I am happy they just fixed it and didn't try any BS with me and I got my free donut and cappuccino while waiting.
I do my own oil changes. I typically drive 30+ minutes on the highway and then drain the engine (only the oil plug and not the engine oil filter) for a few hours. After changing out the filter, I refill 9.3 quarts per manual and I have consistently read slight over the top mark on a level surface. Any thoughts on why Lexus designed the dip stick this way?
Tech Info Resource
Oh, yeah, you'll also lose horsepower to the whipping process.
any engine overfilled will whip oil and cause foam. Doesn't matter from Bentley to Kia
Tech Info Resource
Only a moron would tell you overfilling your oil is without severely damaging consequences. Ray Plumb told me many years ago all the factory CBR600s ran 1/2 quart low because it added 5 hp and prevented early failures...sheesh... the totally ignorant things people say on forums...
drgrant (09-11-17)
