GSF Wheel Spacers
Old 08-29-17, 10:49 AM
gsfdream
gsfdream's Avatar
Default GSF Wheel Spacers
Is anyone running wheel spacers on the stock wheels and stock suspension?
I want the wheels to be more flush with the fenders especially in the front.
The car seems to have a bit of reverse rake and i dont like how that looks.
but if i had spacers it will make it look better with the wheels flush to the body
Old 08-30-17, 02:26 AM
designo
designo's Avatar
I would be careful with wheel spacers on a Lexus car.
I have had no issues with BMW's and Benz's... but I had wheel spacers from different manufacturers and different sizes installed on my GS460 and had vibrations.
Especially with smaller ones requiring extended studs.
Old 09-01-17, 11:53 AM
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
H&R HUBCENTRIC SPACERS
you can go 15mm front and 20mm rear
Old 09-01-17, 08:10 PM
gsfdream
gsfdream's Avatar
ok cool good to know..
Old 09-12-17, 09:27 AM
gsfdream
gsfdream's Avatar
http://www.evasivemotorsports.com/mm...w=&range_high=
so i ended up going with these for my gsf.
I got 15MM all the way around.
I feel like the rear is very close to being flush so a 15mm will push it out just enough to make it look perfect.
And the 15mm for front will be good enough to close some of that distance between the sidewall of the tire and the fender.
I will be making an install video once i get them and i will post it up here for those of you interested.
The only pain in the *** with these will be switching out the studs but its the best type of spacer to use.
The following 2 users liked this post by gsfdream:
designo (09-13-17), jonathanz (09-13-17)
Old 09-13-17, 01:27 PM
IsfClyde
IsfClyde's Avatar
This is with 20mm all around no rubbing issues
Attached Thumbnails GSF Wheel Spacers-photo465.jpg   GSF Wheel Spacers-photo916.jpg
The following 3 users liked this post by IsfClyde:
Boomin (10-30-19), designo (09-14-17), ModInJapan (09-13-17)
Old 09-13-17, 05:34 PM
Amazon
Amazon's Avatar
What brand spacers and what are you lowered on?
Old 09-13-17, 11:57 PM
IsfClyde
IsfClyde's Avatar
H&r wheel spacers. Lowered on rsr springs
Old 09-14-17, 12:11 AM
Amazon
Amazon's Avatar
Did you get h&r drs or drm?
Old 09-14-17, 07:48 AM
gsfdream
gsfdream's Avatar
that honestly looks perfect with the 20mm spacers.
I just did the 15mm to be on the safer side.
tomorrow im going to be doing to work swapping out the studs hopefully it wont be a total pain in the ***
Old 09-14-17, 07:49 AM
gsfdream
gsfdream's Avatar
does the dealer give u any crap about it being lowered regarding service and stuff?
Old 09-14-17, 12:14 PM
IsfClyde
IsfClyde's Avatar
Not at all. But I also been dealing with them since I’ve worked there. Had a ISF previously that was heavily modded
Old 04-21-18, 05:29 AM
designo
designo's Avatar
Fantastic, I'm all set to get the 20's all around then.
Thank You guys
Old 04-21-18, 10:22 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Let us know if you need the spacers !!
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Boomin (10-30-19)
Old 04-22-18, 01:00 AM
designo
designo's Avatar
Check your PM please
Quick Reply: GSF Wheel Spacers
