Any info on Steering-Pump common O-ring leak, DIY?
Old 08-24-17, 01:26 AM
johnnyho
johnnyho's Avatar
Default Any info on Steering-Pump common O-ring leak, DIY?
I have a 2nd gen GS ... alternator going, and looks to be the infamous Power Steering leak coming from above it.
Been reading is commonly the High-pressure Return-line's seal, even that it is "easy" ... but being separated from most of my tools and resources at this time, have to do "meatball surgery" in the field.
Would feel a lot better with a little info on what to expect. But as common as this issue/solution "seems" to be, am finding no "DIY" info or the like (been looking hard!).
Am thinking to address that issue at same time I tackle the alternator.
Actually, have two sub-questions with it ... if am lucky enough to find some special-soul out there that can offer something (for myself and future others):
I've seen the "air control valve" on the pump is a common leak point, also - any help about that or where these two things (I assume) are situated on the pump?
Have also seen where the PS fluid basically "interferes with the stator-brushes" connections, and alternator could be cleaned of to function again....anyone heard or done something as such?
Am grateful for your time and consideration - thank you!!!
Old 08-25-17, 07:44 AM
kevin3344
kevin3344's Avatar
Ended up fixing the high pressure return line on my GS400 twice, and the SC430 I got back in March a few months ago. Fortunately I caught the one on the SC before it took out the alternator. I'm in the habit of checking all the fluids weekly but especially the P/S fluid. It's definitely a problem area on these cars.
Btw, your alternator is more than likely toast might as well replace that as well. I got one with a lifetime warranty from PepBoys back in 2011 for my GS, it's been doing fine ever since.
Old 08-28-17, 12:07 PM
johnnyho
johnnyho's Avatar
Thank you for that!
I was having trouble finding any general info on which port/hose off the pump this is, and what part-description is being replaced ... called a dealer that called it an "e-shaped" gasket (assuming I described correctly). I was expecting something like "crush washers" and/or maybe a banjo-bolt seal or similar (?).
Wonder if you'd know, or have time to shed light on:
*which port off the pump body is it
*what type of seals are looking to be replaced (washer, gasket or like)
In my case, it turned out to be the battery this time. I had gone to Auto Zone hoping for their free battery/alternator test to tell me something useful this time. Why I don't know, the few past times I can remember the diagnosis was always wrong - I'd go in a few days before the component gave out and their "tests" had shown all was "good". I think the test is only as good as the "test-person", and these are not exactly experienced personnel doing them. Anyway, went to an independent garage who's opinion was the battery - which I then replaced for free (under warranty) ... and they were correct. Meantime I know where to get the alternator rebuilt when does happen, for less than a generic Chinese knock-off or a remanufacture with inferior parts.
Thanks for your time ... as always I think these posts will help others in the future, when in need. Thank you for that as well :-)
John
Old 09-02-17, 04:03 PM
98GSOwner
98GSOwner's Avatar
Edit - The design and layout on a GS 3 is different. My manual shows a totally different looking pump. The below is only helpful on a V8 GS.
I just replaced two leaking O-rings on my '98 GS4 power steering pump. See this LS 400 thread, which is what I used to navigate. The GS appears to have the same pump, and doesn't have any brake components in the way:
https://www.clublexus.com/forums/ls-...0-ls400-s.html
My pump was leaking from two places, so I replaced O-rings 1 and 3 from this thread. Of course, the key is to determine where the leak is coming from first, then order parts and tear into it. I don't think all the torque values are included, and I'm a stickler with the torque wrench... For reference, the torque values are:
Rear bracket (back half of pump housing), 4 bolts: 29 ft. lbs.
Bracket for return hose, 2 bolts: 9 ft. lbs.
Bolt for Pressure hose, 1 bolt: 36 ft. lbs.
Mounting bolts to engine block, (2), and mounting nut behind pulley (1): 32 ft. lbs.
Hope this helps!
Old 09-11-17, 01:49 PM
johnnyho
johnnyho's Avatar
That's just awesome, thank you for taking the time to share!
Great to know the LS400 pump is similar - expands the possibilities for info and think I've seen a lot of videos posted on Youtube for the LS.
Many thanks to you 98GSOwner :-) As well as to Kevin3344
Not to "Segway" this too long ... but what I learned meanwhile is not to trust the "free battery and alternator" check you get at the large Parts-store chains, the results are only as good as the employee doing the test - who can be pretty inexperienced. Despite the "Battery - good, low charge" result, I went to a local shop for a second opinion...which was to replace the battery. I was able to replace the battery for better than "free" under its warranty, they had to refund me $8. Present problem (no-start power from batt) is solved, but still have PS fluid soaked hoses and still needs done.
00lexus1u
12
01-18-18 01:46 PM
PlatinumV8
03-27-17 05:40 AM
gsean400
09-08-14 09:54 AM
Soarer78
Performance & Maintenance
06-01-07 06:44 AM
sharneil
06-07-03 08:27 AM
Quick Reply: Any info on Steering-Pump common O-ring leak, DIY?
