Cel on with
Old 08-19-17, 08:53 PM
DSOUN88
DSOUN88's Avatar
Default Cel on with
can someone please send me to the right direction I got a cel code for P0010 and P0325 been doing a lot of research but still scratching my head
Old 08-19-17, 09:26 PM
Lexusdk
Lexusdk's Avatar
What year and which model? GS300/GS350/GS400/GS430/GS450H/GS460?
Old 08-19-17, 10:28 PM
DSOUN88
DSOUN88's Avatar
2nd gen, 2003, gs300 sorry
Old 08-19-17, 10:49 PM
Lexusdk
Lexusdk's Avatar
DSOUN88 (08-19-17)
Old 08-19-17, 11:24 PM
DSOUN88
DSOUN88's Avatar
Do you think these code are related due to the fact of timing
Old 08-20-17, 06:14 AM
Lexusdk
Lexusdk's Avatar
Have you recently changed the timing belt? If anything, I'd first check to see if the connectors for those sensors are seated in properly or undamaged.
Old 08-20-17, 07:45 AM
DSOUN88
DSOUN88's Avatar
No. I bought the car from a friend. He had one of our other friend replaced the spark plugs, wires and VC gasket. After the replacement the car had a misfire so this and check engine light. So this is when I bought the car from my friend and fixed the misfire issue. Now I have these codes.
Old 08-21-17, 12:25 PM
kevin3344
kevin3344's Avatar
Not sure how long you've owned the car, but if you are sure there were no codes prior check to see if your friend used true OEM parts (spark plugs, etc). Believe it or not that could be part of the problem.
If you've only owned the car a short time, it's possible one or more of the codes could have existed prior to your purchase. While the OCV is not that bad to replace the knock sensors are another story. Again you'll want to use true OEM parts and be sure and replace both knock sensors even if you think it's only one.
If it were me I would go one step at a time, clear the codes and see if they come back.
Here is the OCV replacement:
whytry
02-10-18 05:16 AM
sam430
Maintenance
08-04-10 06:23 PM
ILOVEGIRLS
08-31-07 07:58 PM
FutureGS400
Performance
06-19-06 11:53 PM
Quick Reply: Cel on with
