Tire Pressure Wanring Light ON - Whats Wrong?
Old 08-16-17, 02:22 PM
Geroe
Geroe's Avatar
Default Tire Pressure Wanring Light ON - Whats Wrong?
Hello Mates, My car started this about 1 week ago, when I wake up a car in the morning that warning light was on then after couple minutes of riding it went off, PSI is similar.
nowadays warning light won't go off, it's always on, what could be the possible cause? sometimes it shows the yellow square warning on rear right tire too.
Old 08-16-17, 02:28 PM
JDR76
JDR76's Avatar
Do you always keep them at 30 psi? I'd bump those up to 35 or so. 30 is low. I believe somewhere around 30 psi is where the warning comes on.
Geroe (08-16-17)
Old 08-16-17, 02:35 PM
nathantse
nathantse's Avatar
30psi is pretty low. it should be at 36 cold. And up to 38-39 running.
Geroe (08-16-17)
Old 08-16-17, 02:49 PM
Geroe
Geroe's Avatar
Yes, mates, I am always running with 30 PSI and you are right that might cause that warning lights, i will pump it up tomorrow lets see TY
Old 08-16-17, 04:54 PM
audioqueso
audioqueso's Avatar
They're all say 30, but if you check with a psi meter, you'll probably see that the highlighted one is at 30 or closely below it. It happens a lot in the morning during colder seasons. Once you start to drive and heat builds up, it'll fill up more and go away. However, it is best practice to keep the recommended air pressure in the tires especially during colder seasons.
Old 08-17-17, 10:29 AM
Olasek
Olasek's Avatar
Keep recommended tire pressure - it helps with both - gas mileage and tire wear.
Old 08-17-17, 03:48 PM
Rebirthing
Rebirthing's Avatar
I think the recommended tire pressure is 36 all around. It's better to keep it at least at 36.
jrs21c
11-27-19 07:39 AM
Huskers 22
ES - 5th Gen (2007-2012)
10-31-19 05:02 PM
Shrink
10-15-18 02:25 PM
Xwakeboard
11-21-07 03:32 PM
sidgriggs
09-21-06 08:17 AM
Quick Reply: Tire Pressure Wanring Light ON - Whats Wrong?
