LCA rear bolt won't budge - how do I remove
Old 07-24-17, 08:36 AM
Returd
Returd's Avatar
Default LCA rear bolt won't budge - how do I remove
I broke my 24" breaker bar on the rear lower control arm bolt.
I then cut the rear facing nut off the bolt and had the stub showing. I beat on the stub to try to drive the bolt out, still no go, wouldn't move at all..
How do I get this bolt out?
Old 07-24-17, 11:54 AM
Blkexcoupe
Blkexcoupe's Avatar
Order a new one from the dealer and cut the old one off seems to be the most common solution.
Old 07-24-17, 04:12 PM
Returd
Returd's Avatar
thanks, I figured that was the answer but thought I'd check
Old 07-24-17, 09:30 PM
Ramblerman
Ramblerman's Avatar
Are you replacing the control arm? Bolt is froze in sleeve of bushing. Take a slicing wheel on a grinder and go up between arm and mount bracket, be careful to not cut your mount and slice bolt off on each side of arm. This will allow you to drop arm out of mount and pull the bolt ends out of mount. If using arm over then re-bush arm and buy a new bolt. I bought Supra ones and they worked fine.
Old 08-13-17, 11:40 AM
Returd
Returd's Avatar
I pulled arms from a SC400 in a scrap yard today. I ended up pulling the rear cross member. The yard doesn't allow grinders so I cut the rears at home. Cutting the forward side of the rear bolt is pretty dicey. Using a 4 1/2" grinder I couldn't get much bite. Since the cross member didn't matter I busted out the 7" and cut into the mount to get at the bolt, epic.
My driver arm bolts look pretty good but I'm going to attempt to pull the bolts and lather up with anti seize so i don't have to go through this when the time comes..
Old 08-15-17, 06:10 PM
Returd
Returd's Avatar
I checked my driver today and found the rear lower control arm bolts to be removable. I marked position of the camber bolts, removed, brushed the bushing bores out and scotch brited the bolts. I then gave the bolt shanks, threads and contact surfaces of the camber washers a liberal coating of copper anti seize.
I plan on checking in a year and will likely make this an annual maintenance item.
Way easier than cutting bolts, risking damage to the cross member.
KC95SC400
Suspension and Brakes
20
04-14-22 07:41 AM
scott101
15
05-14-13 11:42 AM
newgsman
12
05-24-11 10:23 AM
kit cat
10-30-09 07:44 PM
andrewdees
11-13-07 06:29 PM
Quick Reply: LCA rear bolt won't budge - how do I remove
