'17 IS Turbo F Sport
Just recently picked up one of these with some great discounts for a 48-month lease.Traded in my NX 200t for it.
If anyone recalls, I had an IS 250 F Sport before that.
This car definitely feels quicker. But damn there is a lot of turbo lag. Off the line, without revving, it takes about 0.8 seconds to actually start going anywhere, but it does get up there pretty quickly (in Sport mode).
I saw a thread that had a picture showing how restrictive the stock down-pipe is. Is there a pretty good HP gain with an aftermarket? Or better yet, what is the first mod one would do on this car, that is easily reversible?
All help appreciated. Thanks!
In addition to turbo lag there's also a throttle limitation which holds back the power at early RPM range. We have a re-flash tuning solution that helps to improve this issue as well as add some power. Check out my 200t thread in the performance section, there's a lot of information on our platform.
How does a ECU re-flash work on a leased vehicle though?
EDIT: I guess the answers are in your thread.
So the 245 HP figure is what, at the crank? It only gets 179 at the wheel?
Ughhhh I *knew* there had to be some limitation as well. Even during the test drive I kept telling my friend, "It's like the whole thing is being governed (not just speed limit)"
*241 hp
The turbo lag was one of the drawbacks for me, that's why I decided to fork over the 3k for the 350.
Maybe throwing in a full exhaust and intake would make it feel more power at the low end.
A down pipe would definitely help increase the low range response, but i would recommend getting a tune as well to get the full benefit of it. I've even read about BMW's turbo 4 cylinder having lag problems, its just the downside of these ENGINES.
Ehh... Not so sure about that. I test drove a 2017 WRX before this, well, my girlfriend did, and it had plenty of go. But it also is AWD and 6-speed manual.
Dammit Lexus, why can't you do at least one 6-speed manual model a year?!
What's weird is that the NX did not have this issue. I would burn tires out sometimes if I accelerated too quickly.
I've driven the 328i. It feels a ton more powerful than our cars off the line. it scoots off the line from the moment you floor it and tires are squealing instantaneously throughout first gear. No lag to speak of, really.
They do have turbo lag but when you step on the gas, it goes!
My brother was checking out the motor a few minutes ago. Apparently they left some room for a bigger diverter valve and/or blow-off valve.
Has anyone modified the stock exhaust tips? It looks kind of stupid with the inside pipe sticking out a little bit inside the tips they use.
