New Brakes Grinding
Old 07-22-17, 08:39 PM
travGS350
travGS350's Avatar
Default New Brakes Grinding
I just installed OEM front brake pads bought from the Lexus dealer, on my 2007 AWD GS350. I have done the "break in" stopping and have a low level grinding noise while driving and a loud grind when stopping. Is this normal or did I do something wrong?
Old 07-22-17, 09:41 PM
guzzy92fs
guzzy92fs's Avatar
Did you replace your brake shims for new ones?
and which pads you got the old ones "Black" (04465-30500) or the new "Blue" (04465-30450) ones with low dust?
Old 07-22-17, 09:44 PM
travGS350
travGS350's Avatar
I used the old shims, as the dealer said they usually use the same shims when they replace brake pads. I got the new "blue" pads.
Old 07-22-17, 10:06 PM
guzzy92fs
guzzy92fs's Avatar
Im 99% sure your problem is caused by reusing the shims, never reuse shims, thats a no-no!..Always get new ones! I learned that the hard way.
And they are not that expensive:
https://www.lexuspartsnow.com/parts/...945-30330.html
Old 07-22-17, 10:10 PM
travGS350
travGS350's Avatar
Looks like I'll be getting the shim kit and trying again. Thanks, I'll give an update after I get the new ones on.
Old 07-22-17, 10:32 PM
guzzy92fs
guzzy92fs's Avatar
You're welcome! Also don't forget to lubricate your pads!
Old 07-23-17, 07:07 AM
XJSFan
XJSFan's Avatar
How are your rotors? New or old? Reusing shims is fine as long as you use a good synthetic lube on the back. Have you flushed your brake fluid and are your calipers in good shape?
Old 07-23-17, 07:09 AM
guzzy92fs
guzzy92fs's Avatar
Old fluid can make grinding noise??
Old 07-23-17, 09:49 AM
XJSFan
XJSFan's Avatar
If your fluid is old and it causes a caliper to stick or fail, yes you can get brake noise. Old brake fluid holds moisture and can cause corrosion in your brake system. I just mentioned the above items because they can cause your brake system not to function like it should. Good luck.
Old 07-23-17, 10:03 AM
travGS350
travGS350's Avatar
The rotors were original but didn't feel like they had grooves or were warped. Car has 86,000 miles, I wouldn't imagine the brake fluid being bad.
Old 07-23-17, 11:14 AM
XJSFan
XJSFan's Avatar
A 2007 with 86K miles with original brake fluid is not ideal. Hopefully it's been done with prior servicing. My cars usually get a brake flush every 30K miles or every 3-4 years.
Old 07-23-17, 11:55 AM
Propulsion
Propulsion's Avatar
Just this weekend, while pulling up to a drive thru ATM I noticed a creeking sound coming from the front brakes as I engaged them. It really sounded nasty and embarrassing. The brakes on this car were replaced last Jan 2017 by the previous owner. Any theories on what I'm facing?
Old 07-23-17, 03:25 PM
guzzy92fs
guzzy92fs's Avatar
Same as we are pointing the OP. Double check all the previous mentions with your front brakes.
Old 07-23-17, 04:56 PM
Propulsion
Propulsion's Avatar
Will do, thanks..
Old 07-23-17, 10:32 PM
Unclejake
Unclejake's Avatar
I'd get the wheels off and check you didn't install a pad 'inside out' first. I don't know if it's possible with the GS350, but your description sounds like the backing plate is making contact with the rotor.
Quick Reply: New Brakes Grinding
