Repaired NAV screen and now problem with door locks
Hello all. Longtime lurker, first time poster.
I just received back my repaired NAV screen (digitizer fix) and I reinstalled this morning. After reinstalling (everything works perfectly on the screen), now my power door locks (all of them) won't work unless the ignition is on. I realized this when I went to the hardware store to purchase a socket wrench extension in order to reinstall the two screws at the bottom of the radio unit. The door locks won't work using the key fob, the button on the exterior door handle or the door lock button on the inside of the door. Furthermore, and it stands to reason, the trunk control is experiencing the same issue: tried to open it with the fob and the trunk release button on the trunk itself, while the ignition was off and it wouldn't open. One final thing, the digital clock in between the NAV screen and the radio isn't working either. Not sure if the two issues are connected at all, but I can't seem to find anything on ClubLexus (or anywhere else) that speaks to this issue.
Also, everything was working properly before reinstalling the NAV screen and radio.
Thanks!
Thanks!
