Rear control arms
Rear control arms
Anyone have experience with installing a camber and toe arm in the Rear? My main concern is how you guys went about loosening the bolts/screw on the end closest to the vehicle. Anyone have any advice
Lift both rear wheel tire while working on the rear so the sway bar don't fight with you. It took me about 15 minutes on each side to install SPC rear camber kit with my bagged rwd is200t. I recommend to use XL Flex GearBox Ratcheting I believe its either 17 or 19 mm.
MDSC
11-18-11 03:26 PM
